Banks boost gauge
Old Jul 14, 2025 | 05:32 AM
SkeleCog's Avatar
SkeleCog
8th Gear
Banks boost gauge
Got the banks boost and exhaust temp gauge. Where do I splice in the power wire for the lights? I'm assuming in the switch for the regular dash lights can anyone tell me the wire I'm looking for or where it should go? 93 f250 7.3idi
Old Jul 14, 2025 | 07:59 AM
WCMtn1990's Avatar
WCMtn1990
I would try searching online for a wiring diagram for your model year.
Old Jul 14, 2025 | 03:21 PM
tjc transport's Avatar
tjc transport
i ain't rite
i just tied to a switched power source and if the key was on, the gauge lights were on.
Old Jul 14, 2025 | 10:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
All you need is a test light or meter to find switched power for lights all the time, or when the lights are on.
Old Jul 15, 2025 | 06:57 AM
Olds64's Avatar
Olds64
I ran my coolant temperature, pyrometer and vacuum gauges to 12 VDC IGNITION. Use an ATO fuse tap. You can get them cheaper on Amazon.
https://www.walmart.com/ip/12V-ATO-A...e-M/5003570439
Old Jul 18, 2025 | 05:47 PM
ATS89F350's Avatar
ATS89F350
7th Gear
If it's an incandescent lamp in the gauge, you may want to splice into one of the dash lights (probably the one illuminating the headlight and wiper switches). Then the gauge lamp will be controlled and dimmable by the dash light intensity switch.
Turbo_fox
Jun 13, 2022 01:29 PM
Ghost2017
Dec 25, 2021 05:58 PM
whiteboyslo
Mar 13, 2012 03:07 PM
kupaa
Apr 30, 2011 08:20 PM
Royson12
Jul 9, 2006 04:56 PM
