Sponsored by: Real Truck
CAI and functioning cowl hood
Old Jul 12, 2025 | 09:51 PM
Vendguy's Avatar
Vendguy
8th Gear
I recently installed a fiberglass functioning cowl Hood on my 2008 F350 5.4 gas....and I have a k&n cold air intake.... I'm guessing I should be upgrading fuel injectors now because I'm getting a p0171 and p0174 codes... Anybody have any suggestions for what upgraded injectors I should get.....
Old Jul 12, 2025 | 10:39 PM
85e150's Avatar
85e150
Your problem is probably a malfunctioning MAF caused by contamination from the K&N filter.
EFI systems compensate for changes in air flow caused by new vs. dirty air cleaners.
Old Jul 13, 2025 | 05:11 AM
Vendguy's Avatar
Vendguy
8th Gear
Brand new maf sensor
Old Jul 13, 2025 | 06:41 AM
apache84's Avatar
apache84
New and covered in K&N filter oil is what he's getting at. Did you gain any HP or just more noise? Heres the issue with the so called CAI kits. The OEM system drew real cold air in from outside and in front of the grill. The CAI's draw air in from under the hood where temps are much higher than in the wind. Hood scoop or not, I'll wager the intake temps are higher than pre K&N system.
Old Jul 13, 2025 | 07:22 AM
Vendguy's Avatar
Vendguy
8th Gear
I'm going to have to disagree....this cold air intake is completely enclosed and only draws from hood outside air...it's not just sitting in the engine bay
Old Jul 13, 2025 | 08:45 AM
2015 F-350's Avatar
2015 F-350
Cool hood (no pun intended) - where did you buy it?
Old Jul 13, 2025 | 09:59 AM
ashleyroachclip's Avatar
ashleyroachclip
I wash my k&n filters , have 2 , then use only the slightest amount if oil , and let it sit a fee days , I have one baking right now in fact .
mine is fully enclosed , draws air from the headlight .
The factory air box and associated parts are quite restrictive in comparison to the K&N .
Old Jul 14, 2025 | 06:41 AM
apache84's Avatar
apache84
That is a nice hood. You seeing any gains in mpg or seat of the pants go?
Old Jul 14, 2025 | 07:12 AM
WE3ZS's Avatar
WE3ZS
So does the “cowl hood” which actually looks like it’s a Ram Air style hood and not a cowl design feed it’s captured air into the CAI? If not, how does the hood tie into your thinking that you may need larger fuel injectors? If it does, can you share a few pics of how that is accomplished?
Freeing up the intake air flow will not get you to the point of needing more fuel than the stock injectors can supply, a turbo or supercharger, sure but you are not there yet.
Old Jul 14, 2025 | 08:19 AM
crashz's Avatar
crashz
I'm not really a fan of the aftermarket hoods, but that one looks really good. Fits the truck well. I'd also like to see how the hood and CAI inter-connect. Pics are much appreciated!
I'd go for the cheap fix first and see if you can clean your new MAF sensor. Pull it out and use the specialized spray.
Old Jul 14, 2025 | 03:04 PM
2015 F-350's Avatar
2015 F-350
Hood looks kinda like this:
https://realtruck.com/p/carbon-creat...n-fiber-hoods/
Big Dollars!! And this hood had the ducting integral in the hood:
https://www.americantrucks.com/f350-...-19017000.html
https://www.americantrucks.com/produ...=false&index=7
Old Jul 20, 2025 | 11:24 AM
speakerfritz's Avatar
speakerfritz
I think I have the same hood
all my intercooler pipes are metal now and without the vented hood the metal piping attracts a lot of radiant heat ….big drop in temps just by venting the hood.
do obvious mpg changes but my regens are further apart
rhe the same hood setup on my previous truck was 1400 painted to match on both sides……about 6 years later price went up to 1900 painted on both sides.
Old Jul 20, 2025 | 12:38 PM
Overkill2's Avatar
Overkill2
I run a S&B intake on my truck. It uses the same rubber gasket as the factory box where the intake gets the air from.
I will buy and install one of Run Cool's Wide Flow High Flow when I retire. Much cheaper than a aftermarket hood.
https://hoodlouvers.com/product-cate...-hood-louvers/
I am not having any high temps issues, I am just looking for an escape for the high temps from the turbo and exhaust manifolds. This should also reduce running temps as well. Plus it will look cool AF and be functional. Just FYI for anyone who has never heard of Run Cool hood Louvers.
My truck is black and I would buy the black vent with stainless steel rivets.
I'd most likely do a thread here as well as in the 6.7 section where I spend most of my time...
I'm retiring next year so it won't likely be done until then.
Old Jul 21, 2025 | 06:43 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Having used CAIs on multiple vehicles over the years, you're still getting a LOT of hot engine bay air, unless you fully sealed the box with insulation. Heck the BEST one I ever had was on my 6.0 and even that didn't really reduce intake temps. They claimed a 20hp improvement on the 6.0 but I can't say that I believe it.
That said, I agree with above - a K&N as oiled from the box likely will take out a MAF sensor. They are way over-oiled from the box, and their cleaning/recharge instructions suggest way too much oil. What I did when I used them (haven't bothered in years - today's intakes don't restrict flow very much at all) was I would buy the aerosol cleaner and oil, clean the filter til it was white, then spray enough oil on to make it turn BARELY pink. Then let it sit for at least a few hours, even if it was in the truck, before driving it. Never had a MAF issue that way.
Old Sep 1, 2025 | 06:36 PM
2015 F-350's Avatar
2015 F-350
The link doesn't seem to work?
