A/C Problems... Again
Old Jul 12, 2025 | 04:04 PM
Excurvelle's Avatar
Excurvelle
I was about to report great news that my 05's A/C was finally fixed, cooling great and I was happy, until today.
We were 90 miles from home, A/C cooling perfectly and we stopped for an hour to eat. Came out, started the truck and the A/C was hot, thinking the fan had not ramped up yet we waited. When ready to get on the interstate we saw smoke and a brake clutch smell, I quickly cut off the A/C and looked, the belt was still good and spinning. We drove home the 90 miles with windows down.
I hope the compressor did not seize but at least the clutch spins.
Old Jul 13, 2025 | 07:21 AM
Spicyfly's Avatar
Spicyfly
4wd Low
What work have you already had done to it? By your wording, kind of seems like it’s been a massive project for you.
You were probably smelling/seeing refrigerant. I’m wondering if you have a blockage somewhere and while you were running it, the high side either just got to breaking point and blew a line or the pop-off valve on the back of the compressor /could/ have saved it. Especially if someone was in there working on it, a blockage isn’t out of the realm of possibility.
I’d assume when whoever was working on it filled the system, they added fluorescent dye to the oil too. Look for green oil around the engine compartment.
Old Jul 14, 2025 | 08:05 AM
projectSHO89's Avatar
projectSHO89
Sounds like the clutch burned up.
Old Jul 14, 2025 | 09:16 AM
Spicyfly's Avatar
Spicyfly
4wd Low
There has to be a reason for it though. I’ve never seen an ac clutch just catastrophically fail. Not saying it’s not possible. Just highly unlikely. Wonder if there just wasn’t enough oil in the system.
Old Jul 14, 2025 | 09:34 AM
Excurvelle's Avatar
Excurvelle
The Ex is at a shop, the owner confirmed the compressor is locked up. There is a possibility it is under a parts warranty, we shall see.
Old Jul 15, 2025 | 04:29 PM
Excurvelle's Avatar
Excurvelle
Truck is almost finished, the compressor locked and did not put much junk in the system, fortunately. Told him I want Ice Cubes out the vents.
Old Jul 16, 2025 | 10:29 PM
John in OkieLand's Avatar
John in OkieLand
I saw a video a while back, they replaced the Freon with Butane.
Claimed that it would get 10 times colder than Freon ???
Old Jul 17, 2025 | 06:35 AM
projectSHO89
Hydrocarbons (propane, butane, etc) do perform well as refrigerants. However, just don't get a leak...
Old Jul 17, 2025 | 02:24 PM
Spicyfly's Avatar
Spicyfly
4wd Low
Well they used Propane before R-12 in cars and they still use it in some appliances. They call it R-290
Yngvarr666
General Automotive Discussion
Apr 24, 2018 09:25 AM
northwindone
Modular V10 (6.8l)
Jan 20, 2014 11:14 PM
ajaxx
13
Oct 3, 2012 11:57 PM
RoadJunkie
6.4L Power Stroke Diesel
May 29, 2011 02:49 PM
tstraigis
Dec 6, 2007 10:26 PM
