New C6 forward clutch steels missing teeth...
Old Jul 10, 2025 | 12:02 PM
Lahti35's Avatar
Lahti35
I got my order of new steels for the forward and direct clutches in my '68 C6 and the new ones are missing a few teeth 180 degrees opposite each other in two locations. They are brand new and look to be made this way. The steels are .078" thick.
My originals had teeth 360 degrees around the circumference. Is this the way they're making them these days or did I get some off brand junk I should replace with something that looks like the originals?
Old Jul 10, 2025 | 05:05 PM
jk080's Avatar
jk080
Transmission Rebuilder
That is the way they are made now, it won't cause any issues.
Old Jul 11, 2025 | 09:26 AM
Lahti35's Avatar
Lahti35
Thank you. I only rebuild transmissions very occasionally, so I had not seen these types of plates. I'll use them and not worry about it. Thanks again!
Old Jul 30, 2025 | 11:02 AM
mmerlinn's Avatar
mmerlinn
Steel plates may or may not have a full complement of teeth even from the factory for variouc reasons. The most common reason is for identification of the plates. Plates of different thicknesses may have missing teeth and/or notched teeth to identify how thick they are. I don't remember whether this applies to C6 plates or not, but I would not worry about it.
SRD4X4
Mar 23, 2007 05:47 AM
frankster123
Jul 5, 2003 07:30 AM
orangeford
Aug 13, 2001 11:13 PM
