dieseling problem
Old Dec 6, 2003 | 06:01 PM
chris69's Avatar
chris69
dieseling problem
my 1978 f-150, 400 engine diesels when i shut it off. my timing is not off. what is wrong
Old Dec 6, 2003 | 06:54 PM
79 250 lariat 4x4's Avatar
79 250 lariat 4x4
try running higher octane fuel
Old Dec 6, 2003 | 07:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Your carb idle is set too high. You can find out about carb settings in the Fuel systems forum.
Old Dec 6, 2003 | 08:39 PM
68FordCA's Avatar
68FordCA
Hehe..Torque beat me to it. Idle is a bit too high, you will have to tweak it a bit to find the "sweet" spot, where it will idle fine but not diesel when shut down.
Old Dec 6, 2003 | 08:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
A good tune up will make it easier to find that sweet spot. An old engine that is down on compression and dying will be hard to get to run correctly.
Old Dec 6, 2003 | 10:58 PM
74 F100 351m's Avatar
74 F100 351m
I would say it might be a streched timing chain.
Old Dec 7, 2003 | 04:52 AM
willd's Avatar
willd
Carbon deposits on exhaust valve or combustion chamber will cause it when you combine too much idle air and no load on the engine ie. with an auto. Try shutting it off in gear or letting the clutch out in gear with the brakes applied. Sometimes works for auto's too.
