I am having an issue with my Speedo it only stays on 15 mph, sometimes it'll try to catch up with it self.
Whats been replaced so far:
- Speedo Gears (ALL TESTED)
- Speed sensor
- Speed cable
I'm praying its not speedometer head, if so how do I referbish it my self.
So when you are stopped it still shows 15mph? Did you try hooking up a drill to the speedometer cable to see if that makes the speedometer work?
Many years ago I sent a speedometer to Powl’s Speedometer Service to get fixed. There were several guys on JeepForum that sent gauges to D & M Restoration to have refurbished.
No it goes to zero at stop. But it wont hardly go over 15 mph. And it'll often be just bellow 15. Also the transmission is brand new, the shop that installed it said the speedo worked when they test drove it. Although I find that hard to believe since it did not work when we first drove it home. BTW the drive gear is green, the one in the tail shaft. Not the one on the sensor. Yes it does still work when you spin the cable manually.
How to make sure you have the right gear inside the transmission tail housing? With the speed sensor removed from the transmission can you turn the gear by hand or does it feel locked in place?
