Sponsored by: Auxito
Installed heater core only
Old Jul 2, 2025 | 08:30 PM
FLFordF150's Avatar
FLFordF150
Installed heater core only (Will do hose and connections later.
key guard on ignition lock broke
now my cruise control is not working
2000 4.2 F150
Old Jul 3, 2025 | 08:52 AM
Stillconfused's Avatar
Stillconfused
2000 4.2 F150
Im confused. Ya replaced heater core?
That's an feat in itself
You gor magic tricks or ??
Old Jul 3, 2025 | 10:07 AM
FLFordF150's Avatar
FLFordF150
why are you confused?
I loosened the dash and installed the heater core and bolted dash back. I however didn’t buy lines fittings and hoses for the under hood part.
Old Jul 3, 2025 | 01:07 PM
BareBonesXL's Avatar
BareBonesXL
2000 4.2 F150
It's kind of an odd post. Reporting a few random things. Good luck with it though.
Old Jul 3, 2025 | 01:52 PM
FLFordF150's Avatar
FLFordF150
I see google has post where others asked the same thing cruise stopped working after pulling dash to put in a heater core.
Old Jul 3, 2025 | 02:12 PM
BareBonesXL
So, you're asking how to fix cruise control?
Old Jul 3, 2025 | 02:17 PM
FLFordF150's Avatar
FLFordF150
or what likely caused it to stop working by removing dash
I know there’s a sensor near brake fluid that often affects cruise bc a previous F150 I had to change sensor
Old Jul 3, 2025 | 02:18 PM
FLFordF150's Avatar
FLFordF150
Old Jul 4, 2025 | 08:51 PM
FLFordF150's Avatar
FLFordF150
Had absolutely no issues with my cruise control prior to pulling my dash and installing heater core.
I will hook hoses up later.
others have posted online that cruise stopped after pulling dash for heater core. I only slide passenger side out as much as possible to do the job
anything I could have unplugged to stop cruise from working? I know there’s a sensor by brake fluid but I haven’t touched that.
Old Jul 4, 2025 | 08:52 PM
FLFordF150's Avatar
FLFordF150
I do see a connector nothing plugged in below my steering wheel by the metal brace to left of the obd port.
Old Jul 5, 2025 | 06:16 AM
manicmechanic007's Avatar
manicmechanic007
There is a bunch of connectors down there on the left side of the dash
One of them is unplugged coming from the steering column clockspring most likely
Check the codes
Old Jul 5, 2025 | 09:12 AM
RLXXI's Avatar
RLXXI
My money is on a busted clock spring (aka sliding contact). Common issue when rookies try to DIY. Seen it time and time again. Did it myself when I was still wet behind the ears.
Old Jul 5, 2025 | 03:08 PM
Oregon Kickstart's Avatar
Oregon Kickstart
So, is there a technique or pointers for those that are inexperienced with them? Just trying to soak up knowledge here...
Old Jul 6, 2025 | 06:20 AM
manicmechanic007
Yes,
You simply unplug the clockspring before you start the work and then do not let it rotate while out
You need to trace the wires from the clockspring down to their connectors (2)
If they are plugged in, you probably broke the sliding contact inside
Code test to verify
Old Jul 6, 2025 | 07:05 AM
RLXXI's Avatar
RLXXI
I always wrap the driver seatbelt around the steering wheel to prevent it from turning while the column is disconnected during these type of jobs. That's how 99.9% what happens when the column is moved/removed.
