rocker arm questions
Old Dec 6, 2003 | 04:31 PM
MARC's Avatar
MARC
I have 2 sets of rocker arms, a lower and a higher ratio.
Is the gap still .19 for each?
is it more advantageous to use the higher ratio?
with switching from the 471 heads to 113 heads, how do I know which length push rod to use?
thanks for any input
Old Dec 7, 2003 | 09:08 PM
pcmenten's Avatar
pcmenten
The higher ratio rockers will give more lift and slightly more effective duration. It will make the cam 'bigger'. More power, but perhaps less fuel mileage.
I can't help with the pushrods. I wouldn't have thought that there was a difference.
Nice heads. Are they going on a 292?
Old Dec 8, 2003 | 12:18 AM
MARC's Avatar
MARC
thanks
the heads are going on a 59 f-100 4x4 with a 292
Just bought a set of ram horn exhaust manifolds for a dual exhaust.
should help the horsepower quite a bit
mjb1962
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 30, 2021 09:17 AM
46yblock
May 6, 2005 07:18 PM
luvinfords
Apr 21, 2005 05:41 PM
76 F250 4X4
Oct 16, 2004 12:40 AM
towin toys
Apr 19, 2002 01:37 AM
