How did you guys lift the front? Spacers or taller springs? Which did you use? Still researching for the 7.3 (which requires heavier springs) not sure which route to take. Not many options for this size engine.
The link above is for a D60 front axle. Found in stock F-350 4x4 trucks, or swapped into F-250 4x4. The shackle reversal moves the leaf spring shackle from the front of the axle to the rear. Most people report improved ride quality with it.
