EGR delete Help ?
Old Jul 5, 2025 | 11:15 AM
wwhite's Avatar
wwhite
Originally Posted by Kenneth Maddux
Does this mean I have to put one on my headers? Or just get a delete kit?
if you have a Y pipe, install there, exactly like the factory Y pipe crossover tube O2 bung.
Old Jul 6, 2025 | 12:14 PM
Kenneth Maddux's Avatar
Kenneth Maddux
unless I can buy them I just have headers on ATM
Old Jul 6, 2025 | 12:21 PM
Kenneth Maddux
Has anyone install a no weld bung on headers before?
Old Jul 7, 2025 | 10:18 AM
wwhite's Avatar
wwhite
That would probably leak.
If you have shortys, install the bung in the exhaust pipe.
Old Jul 9, 2025 | 05:27 AM
torq'ta 5 8's Avatar
torq'ta 5 8
I have a no weld bung, on driver side for my A/F ratio, used rtv to keep it from sliding the gasket, around, until I got clamps tight(2yrs ago), as the man falling out a 10 story window kept saying...so far so good
Old Jul 9, 2025 | 08:20 AM
wwhite's Avatar
wwhite
In the header or the exhaust pipe, shortys or long tubes?
Old Jul 10, 2025 | 05:04 AM
torq'ta 5 8
Shorty's, exhaust pipe, it said 18" from collector.
Old Jul 10, 2025 | 08:32 AM
wwhite's Avatar
wwhite
Since installing with headers and just mufflers and pipes, I get rough idle, hard starts, etc. No cats have been installed, so no place for smog sensor etc.
You say you have mufflers and pipes, but you also say you just have headers on.
@Kenneth Maddux this is your answer. Install the O2 sensor 18" from the collector in you exhaust pipe.
Old Aug 10, 2025 | 10:01 AM
Kenneth Maddux
Headers are on the motor already. I have no pipes (muffler or pipes).
Old Aug 13, 2025 | 12:47 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I have a 1992 F-150 with a 302 EFI. Since installing with headers and just mufflers and pipes, I get rough idle, hard starts, etc. No cats have been installed, so no place for smog sensor etc. I do not want that crap on there anyway. So what delete kit would I need for the EGR delete ? Is the A.I.R the same ? I'm sure I could find a Youtube video on how to do, but have no clue on what I would all need. Anyone do this on a 302 yet? Can anyone direct me to the correct and complete set to do this?
Thanks
So you have headers, mufflers and pipes?
As the others have pointed out: deleting the EGR and air injection system isn’t going to solve the problem. The lack of an oxygen sensor is causing the engine to run poorly.
Then you don’t have anything but the headers.
Thank you. I'm going to check to see if it is the 02 sensor. It was installed on the Cat.(see pic)
I have a red arrow pointing to the oxygen sensor. It appears that you have a black circle around the air injection pipe. Is that what you are asking about?
So where do I install it???? Really do not want to drill on the headers seeig there already in there
What Hedman headers did you buy? The long tubes I bought from Pacesetter has an O2 bung in each header.
Old Sep 9, 2025 | 05:45 PM
Kenneth Maddux
@My4Fordtrucks Check your pm please. Thank you guys, I'm more of a visual guy more than anything. I hope I can get this solved soon before that snow hits the ground. If it goes on there, I want to put it back, minus the cats of course.
"The sensor needs to be pointed downward "------????
What I have ATM
What I have ATM
Old Sep 10, 2025 | 08:08 AM
wwhite's Avatar
wwhite
Pretty sure you won't be able to install the muffler like that, nor would you want to. There is a frame cross member and a transmission in the way.
The best place for the O2 sensor is in the collector of your long tube. I'd put it at the 12 o'clock position on the collector, and the bung should have an angle, no more than 10*.
My bungs are on the inside of the collector, cannot see in picture, but not ideal, as the trans is in the way, had to install on drivers side.
I'm going to modify my Y pipe, either install a bung there, or add a tube like the stock one has that joins the two exhaust pipes together.
stevenjf88
Aug 13, 2015 05:18 PM
96fonefitty
Exhaust Systems
Feb 8, 2014 08:11 PM
cj96f150
Nov 14, 2008 12:57 AM
FordMan94
Feb 12, 2004 04:51 PM
DRanchero
Jul 30, 2003 09:23 AM
