Sponsored by: Real Truck
AC Help Needed!
Old Jun 27, 2025 | 11:16 PM
Various's Avatar
Various
4th Gear
AC Help Needed!
2013 F250 6.2 had a few leaks. Shop decided to replace the AC lines and condenser. Still leaked to we determined it was the evap. In the meantime while waiting for a shop to get me on the scheduled, I went on ahead and refilled with some freon and noticed my AC wasn’t as cold as it USED to be…. didn’t think much of it. I ended up getting the EVAP core replaced and that cured the leaks. Shop vacuumed and filled the R-134 to proper specs… STILL the AC does not blow as cold as it used to be. The PSI is in proper range. When idle…. blows semi cold and on highway it blows colder but not ice cold as it USED to be. We then decided to replace the AC Compressor- SAME RESULTS. The low pressure line and evap is dripping with condensation but it’s still not as cold as it used to be coming out the vents. I’m leaning towards possibly the new condenser being the issue. Any thoughts?
Old Jun 27, 2025 | 11:34 PM
Truckwardo's Avatar
Truckwardo
The Gas quality itself could be poor. If they drained all the pag and the machine is calibrated and the gas level is correct and properly leak tested it has to be the gas. When serviced they need a little dessicant filter changed, new O rings and new shcraeder valves. And the cabin air filter needs to be fresh. That dessicant filter can effect performance if fouled.
Old Jun 27, 2025 | 11:55 PM
Various's Avatar
Various
4th Gear
I doubt it’s bad gas bc i’ve had it refilled by 3 different shops
Old Jun 28, 2025 | 12:04 AM
Truckwardo's Avatar
Truckwardo
All local shops would be getting gas at the same place. But if you already changed all the parts and used 3 different shops then I can't think of a reason other than maybe a temperature sender is sending faulty readings and disengaging the compressor clutch prematurely. Not sure it would on max tho. Guess I would manually power the compressor clutch and measure if it gets colder than baseline. Leave it engaged for several minutes. Or swap the sensor if it's cheap and in an easy spot to get at. Not sure how that system works. Clogged dessicant tube would be my next guess. But I'm sure they would have looked. Shraeder valve could leak. But they check. There could also be a fault in the pressure sensors. Change both.
So if I'm stuck and just guessing and don't have tools to check exact values. Pressure sensors and the interior temperature sensor. i haven't fixed an AC system in 7 years.
Old Jun 28, 2025 | 10:31 AM
Pikachu's Avatar
Pikachu
How are the system pressures running, and what was the ambient temperature at the time?
Old Jun 29, 2025 | 07:38 AM
Various's Avatar
Various
4th Gear
Around 100 degrees with 50 PSI and 250 PSI
Old Jun 29, 2025 | 11:36 AM
Pikachu's Avatar
Pikachu
Is the compressor cycling or staying engaged most of the time? At 100 ambient, I'd think the high side would be a little higher than that. Can you get to the expansion valve at the firewall and give it a little tap or two and see if anything changes? The pressure line going to the txv should be pretty hot. Is the tube on the suction side of the evap coil cold, cool or warm-ish?
Old Jun 29, 2025 | 02:47 PM
ashleyroachclip's Avatar
ashleyroachclip
There is a filter online going into the evaporator .
it should be changed whenever the system has been opened .
it is a screen like fiter that sits inside the line .
I had a heck of a time finding it on my 99 v10 .
Old Jun 29, 2025 | 03:46 PM
Various's Avatar
Various
4th Gear
The compressor is staying on consistently as it should. I can try tapping the expansion valve. The high pressure line is very hot and the low pressure lineand evap both drip condensation. The only time the air It gets really cold as it should is when i’m driving through the rain which cools down ac condenser. I’m thinking the condenser is just the weak link. Looks like a silver aftermarket cheap condenser
Old Jun 29, 2025 | 04:31 PM
Pikachu's Avatar
Pikachu
If you're talking about the orifice tube, his truck doesn't have one.
Old Jun 29, 2025 | 04:37 PM
Pikachu's Avatar
Pikachu
If it was a crappy condenser, I'm thinking it would drive the high side pressure higher. But, if it's a different design than OEM, it might use a different refrigerant charge amount. Even though I got my condenser from a dealer, it's redesigned and calls for about 8 ounces less refrigerant than stock.
pedrodominion
May 20, 2024 11:07 PM
finsfree
2004 - 2008 F150
Jul 19, 2022 06:28 AM
Hyakkimaru
26
Jul 17, 2022 11:08 AM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
golfboy17
15
Aug 11, 2010 03:45 PM
