Front end shake
Old Jun 26, 2025 | 06:06 PM
Butch5's Avatar
Butch5
Front end shake
Hello, I've got a question on a 96 Ranger. I've got a shake in the front end. I thought it was a bad tire so I replaced the front tires. That didn't solve the problem. I'm wondering if it could be wheel bearings. But they are not making noise. I checked the ball joints and I don't see any movement when I rock the wheels. When I rock the wheel at 3 and 9 and 6 and 12. I get some play. However, I don't know what amount is excessive. When rock the wheel I don't see any movement at the ball joints, but it does seem like the rotor is rocking which is what makes me suspect the ball joints. But, as O said, they are not making any noise. Also, the play is the same on both front wheels. Any help would be appreciated.
Old Jun 27, 2025 | 01:59 PM
nelbur's Avatar
nelbur
It might help if you described the nature of the shake, and when you hear or feel it. Do you have 2 or 4 wheel drive?
Old Jun 27, 2025 | 02:08 PM
Butch5's Avatar
Butch5
It feels like an out of round tire. Almost like its going up and down. You can feek it a low speeds but, it gets worse around 55-65.
Old Jun 28, 2025 | 09:08 PM
nelbur's Avatar
nelbur
It sounds like a tire or wheel problem. If you spin the wheels next to something like a jack stand you can see variation. Pay attention to how true the rims run. A bent rim can be difficult to figure out since changing tires doesn't solve the problem.
00Dave
19
May 5, 2022 07:09 PM
k1c
Jul 29, 2012 12:25 PM
03KingRanch250
Mar 8, 2008 05:49 AM
skilife17
1997 - 2003 F150
Jan 11, 2006 12:15 PM
phoneman71
Nov 25, 2004 07:55 PM
