Tech Specs
So what do the underlined numbers mean below? Are they for each engine size, each gear ratio, or the combination? I am pulling the VINs from CarFax and then looking them up, but the VIN Decoder has no explanation for what these mean. Some of the numbers change if I go from the 5.5 bed to the 6.5 bed, or from XLT to Lariat, but I would really like to know so I can be more aware of what I need to look for. I want to have plenty of extra room so that I am not overburdening the truck.
Wt Distributing Hitch - Max Trailer Wt.10800, 10800, 8900, 8900, 9000, 9000, 7000, 5000 lbs 5000.0 min 11700.0 max
Wt Distributing Hitch - Max Tongue Wt.1080, 1080, 890, 890, 900, 900, 700, 500 lbs 500.0 min 1170.0 max
Fifth Wheel Hitch - Max Trailer Wt.10000, 10000, 8800, 8800, 8900, 8900 lbs 7000.0 min 11400.0 max
Fifth Wheel Hitch - Max Tongue Wt.2200, 2200, 2225, 2225, 2500, 2500 lbs 1750.0 min 2850.0 max
Maximum Trailering Capacity10800, 10800, 8900, 8900, 9000, 9000, 7000, 5000 lbs 5000.0 min 11700.0 max
Thom Scott
It’s showing you all the weight options available and that’s it. Nothing more.
I’d recommended just googling up the proper year F150 towing guide for the truck of your choice and you’ll be headed in the right direction.
With a gooseneck and how it affects payload, you may be stuck having to look for the near mythical HDPP package F150. Those are rare and an F250 may be the better buy for higher altitude towing.
