Ignition actuator rod replacement
Old Jun 25, 2025 | 08:43 PM
casey_kreilein's Avatar
casey_kreilein
My ignition actuator rod broke so I took the steering column apart to replace it. I’m ready to start putting it all back together but the portion of the system that rides in the lower part of the steering column won’t come out. I’m trying not to break it pulling it out but I can’t figure out what it is hanging up on.
Any help is appreciated.
This part won’t come out of the slot it rides inside.
Old Jun 26, 2025 | 09:55 AM
C6Scott's Avatar
C6Scott
The steel lever is what’s holding it in. That lever locks into the shift tube so the truck can’t be put in gear with the key off. It’s showing in the top picture. Knock the pin out and the lower actuator will come out.
Old Jun 26, 2025 | 07:36 PM
casey_kreilein
I was hoping it wouldn’t be that but had a feeling. I pulled it out and got everything back together. Truck is running again and back to being a daily driver.
I appreciate the help.
Duke 79
Sep 26, 2023 07:08 PM
TXwingnutt
13
Sep 29, 2022 04:55 PM
te47823
Aug 15, 2022 06:22 PM
big_brown_88_idi
Jan 23, 2022 01:03 PM
ThomasD
Dec 21, 2021 07:20 PM
