4R75E OEM filter replace?
Old Jun 25, 2025 | 07:48 AM
JWA's Avatar
JWA
Old Jun 25, 2025 | 08:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the trans hasn't failed, the internal filter is still good.
Old Jun 26, 2025 | 04:16 AM
JWA's Avatar
JWA
Thanks Mark----I thought that was the case but just wanted to confirm.
Called the local dealer for a replacement (Motorcraft FT=105, they tell me its an obsoleted part number so they cannot order or even suggest a replacement! Any one recommend a suitable high-quality alternative brand?
TIA!
Old Jun 26, 2025 | 10:57 AM
meborder's Avatar
meborder
In the past I used ATP filter kits on my AOD. They came with a nice rubber gasket that never gave me any issues.
I don’t think I’ve dropped a transmission pan since around 1998 or 1999 though.
knowing what Mark confirms to be true, I have just done fluid exchanges since the early 2000’s. Fresh fluids every 60,000-100,000 depending on use and my transmission all see well over 200k before I stop driving the car.
the only exception to this might be the Subaru I currently daily. I changed it at 120k and again at 200k. But at 240k it’s starting to flare the 2-3 shift of the fluid is below 60 degrees. But still going at 240k, I just feather the gas on the shift until it warms up. I might swap the fluid to Valvoline max life which is a little thinner (closer to mercon LV in viscosity) since it seems to like the thinner fluid.
But with a dead air conditioner, now, I’m debating on just letting it go. Just saves miles on the nicer cars.
Old Jun 27, 2025 | 05:22 AM
JWA's Avatar
JWA
Thanks for the advice and suggestions---makes me glad to be a member here!
JWA
Jun 25, 2025 08:54 AM
speakerfritz
Jul 24, 2014 08:59 AM
Leon82
Dec 27, 2013 10:07 PM
PirateGhost
Sep 27, 2011 08:26 PM
