Magic Box or similar?
Old Jun 19, 2025 | 05:51 PM
rhino_160's Avatar
rhino_160
2022 F350 with Sync 4
I eat lunch in my truck often and would like to watch a show on my sync 4 screen. I’ve seen these magic boxes and others advertise it will play Netflix, prime video, etc.
Anyone have any luck with any particular brand that is simple to work and also allows for the movie to play full screen?
Magic Box 3.0 is pretty pricey compared to others so hoping someone with real-world experience can chime in. Thanks in advance.
Old Jun 20, 2025 | 06:01 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Haven't used anything like that because I have no interest in it...but there's a new feature on some trucks (my '25 has it) where it actually already has a Youtube app installed on it. I will likely NEVER use it but it's there and can be used when the truck is in park.
Old Jun 20, 2025 | 06:32 AM
B-ManFX4's Avatar
B-ManFX4
I use a DashLynx to do exactly that. My truck doesn't have Sync 4.0 but can't comment on that. Works fine.
Old Jun 20, 2025 | 09:15 AM
4wd6.7L's Avatar
4wd6.7L
I took a quick look, it says USB to hdmi, what are you plugging into it?
Old Jun 20, 2025 | 09:46 AM
B-ManFX4's Avatar
B-ManFX4
I plug the Dashlinx into a USB port in the center console. After a second or two, the Dashlinx takes over the center screen. I then plug a Roku stick into the Dashlinx USB port. The Roku has a RF remote instead of an IR remote so it works with the console closed and everything hidden.
Old Jun 21, 2025 | 01:52 PM
rhino_160's Avatar
rhino_160
I opted for the elite car box 4.0. Should arrive next week and will see if it’s as simplistic as they say…. Plug it in, allow it to hotspot to my phone, and it has all the apps (Netflix, etc) on it to play while I eat lunch. To be continued…..
Old Jul 1, 2025 | 08:45 PM
John McCarron's Avatar
John McCarron
4wd Low
I’ve had the original Magicbox and now have the 2.0 version. The first one was very clunky, the 2.0 works pretty well. I run YouTube TV and MLB constantly. If the 3.0 is as big of an upgrade from 2.0 as 2.0 was from the original, I bet it works great. FYI, what makes it really shine is putting a data only sim in it. Sharing the internet from your phone isn’t ideal. Requires manual intervention. With a dedicated sim, it’s seamless. 17 F350 with sync 3.
Old Jul 2, 2025 | 03:19 PM
rhino_160's Avatar
rhino_160
So far the 4.0 box is working great. I use the onboard AT&T modem and it auto connects without issue. Streams in HD and operates just like I needed it to. Only a couple days of use but currently I would recommend.
Old Aug 23, 2025 | 01:27 PM
roberthleeii's Avatar
roberthleeii
Any updates after a month+ of use?
Old Aug 25, 2025 | 10:44 AM
rhino_160's Avatar
rhino_160
Works well for my needs. They tell you to unplug it if you are not using it as it's basically a computer, even though your USB plug times out after the truck is off. My only complaint is sometimes on YOUTUBE, it's hard to get the search button to depress in the upper right corner. I don't know if this is an app issue or the 12' screen but after a few quick taps, it usually takes. All in all, it's great for my needs.
You will need to disable your phone from CarPlay and just bluetooth to this device as it puts CarPlay on the screen for you. Good luck
Old Aug 25, 2025 | 08:04 PM
6.2caribou's Avatar
6.2caribou
Why not just pick up an inexpensive tablet and hotspot it off your phone. Then you have a video source that you can use anywhere.
Old Oct 17, 2025 | 05:00 PM
fastbike02's Avatar
fastbike02
you happen to have a link for the one you bought?
Old Oct 20, 2025 | 01:45 PM
rhino_160's Avatar
rhino_160
https://streamtoyourcar.com/products/elitecarbox4
they typically have some discount code at the top. good luck
ArmyLifer
Mar 5, 2025 11:16 PM
3Mike6
N. California Chapter
Jan 3, 2010 11:48 PM
Truckin4life
Apr 2, 2008 11:25 PM
