windshield question
Old Dec 6, 2003 | 09:16 AM
hell on wheels's Avatar
hell on wheels
windshield question
Does anyone know if the windshields on the 73-79 ford trucks were the same???Is it possible to swap them out no matter no what the year of the two trucks
What about the back glass is it possible to swap a slider window with a solid back window???
Any help please!
Thanks,
Dan
Old Dec 6, 2003 | 11:37 AM
fordman428's Avatar
fordman428
yes i believe they will work my dad took the front and back glass out of a 73 f-250 and put it in a 78 f750 grain truck. good luck
Old Dec 6, 2003 | 11:44 AM
Ford Puller's Avatar
Ford Puller
Glass
From '73-'79 windshiels were the same . You can swap the solid glass for a slider. Brian
Old Dec 6, 2003 | 12:26 PM
hell on wheels
Okay thanks my 78 F-150 has a good windshield and slider window but I'm trying to get a older truck that has a good cab on it but no windshield and solid back window.So I will need to swap them out.
Thanks,
Dan
Old Dec 6, 2003 | 07:25 PM
Tattoo Matt's Avatar
Tattoo Matt
I checked into getting a new windsheild for my 76...you can get a new one for around $180.00 installed...I think thats the way to go!!
Old Dec 6, 2003 | 10:51 PM
74 F100 351m's Avatar
74 F100 351m
It took my son and 4 cusons, and 1 brother inlaw, 4 hours to get his window in his 78.
Old Dec 7, 2003 | 01:45 AM
plowpusher's Avatar
plowpusher
the winsheilds are the same 73-79 the rear are the same 73-96 when you change out the windsheild use a spat lube and be generous with it take your time your 78 should have the lock strip type gasket pop out the lock strip loosen the rest of the rest of the gasket and gently push out the glass use your 78 gasket on the other truck there is two schools of thought on installing put the gasket on the window use a cord ithe gasket groove and put
it together as one unit or put the gasket on the truck and put the windsheild into it use a stiff piece of plastic for prying a screw drive on the edge of the glass will shatter it
Old Dec 7, 2003 | 02:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use a new gasket to avoid the possibility of leaks. A new gasket is also more flexible than an old dry one. Make sure there are no scratches in the paint under the gasket or rust will eat your truck...
Old Dec 7, 2003 | 08:46 AM
hell on wheels
Well I think I will just have somebody do it for me like a automotive window installer.One time a guy came out to install a windshield in my dad's 89 F-250 and it took him about an hour by himself pulling the old one out and popping the new one in.
Thanks,
Dan
Old Dec 7, 2003 | 10:11 AM
ecarter50's Avatar
ecarter50
Windshields are the same 67-79.
Mikulh
Sep 21, 2018 04:04 PM
mixup
Jul 10, 2014 07:05 PM
vwfreak
18
Jul 5, 2013 09:13 PM
CharlieLed
Aug 16, 2006 01:15 PM
cujo8
Jul 11, 2006 03:32 PM
