carburetor replacement
Old Jun 16, 2025 | 12:29 PM
brockwood's Avatar
brockwood
I have a '60 with the inline 6 and need to replace the carb. Anybody have a good recommendation for a modern replacement?
Old Jun 16, 2025 | 06:55 PM
spurredon's Avatar
spurredon
Nothing wrong with the Holley 1904's they came with when in good condition. Easy to rebuild.
Old Jun 17, 2025 | 12:19 PM
brockwood's Avatar
brockwood
Mine has been rebuilt more than once and is needing to be replaced.
I was hoping somebody had a recommendation for a modern replacement.
The ones I see for sale are parts only and the asking price for a used unit are outrageous
Old Jun 17, 2025 | 06:23 PM
swann79's Avatar
swann79
Why do you think it needs replaced? You can pretty much rebuild them as many times as you need to. Every 5 years or so isn't that far-fetched. Rebuild with parts straight from Holley for best results. I wouldn't change it unless I knew for sure it was bad.
Old Jun 21, 2025 | 06:47 AM
manglass's Avatar
manglass
What is wrong that is causing the need for replacement. That's a solid carburetor and almost everything on it can be repaired or combned with a parts carburetor to make a good, useable unit.
If you must have a replacement carburetor, a rebuilt unit is available through Rock Auto as Autoline C716. I think I would use that over the new units available on Ebay.
Lou Manglass
Old Jun 26, 2025 | 01:20 PM
JohnNewb's Avatar
JohnNewb
I put a Brazilian Universal carburetor on mine that seems okay. I have not driven it much though. Mine had a wrong carburetor but I had the same problem finding a Holly. Sky high prices for unknown condition.
t5killer
Oct 22, 2023 12:10 PM
VanGo3
General Automotive Discussion
Jul 8, 2021 09:18 PM
chetmac
Jan 28, 2004 04:01 PM
TwoF150
Aftermarket Products
Apr 30, 2003 09:46 PM
