fan blade orientation
Old Jun 13, 2025 | 05:52 PM
mackendw's Avatar
mackendw
I took the fan blade off the fan clutch to clean the shaft and dirt & grime build up on the fan clutch. it was disgusting. tested the fan
clutch spring with a heat gun and it's opening the spring tension when heat is applied and returns when cool air hits it.
now for the question. when I cleaned the layers of crap off the blades, I saw the Ford logo stamped onto one side of the blades
and the word FRONT. when I re-installed the blade I put the side with these 2 stamped words towards the front of the truck ie:
facing the radiator. Is this correct? I held the fan up and looked at the blades when the blade is spun in a clockwise motion
and to me it does not appear that it would draw air thru the rad towards the motor....
thoughts?
Old Jun 13, 2025 | 05:56 PM
seschenburg's Avatar
seschenburg
Whichever way blows toward the engine is the correct way.
Old Jun 13, 2025 | 06:14 PM
mackendw's Avatar
mackendw
I see what is confusing me...the belt direction around the water pump will spin the blade COUNTER-clockwise fo the water pump and fan blade. That makes sense.
yeet
Mar 3, 2024 12:02 PM
sandymane
28
Nov 11, 2019 03:55 PM
79FordBlake
Aug 6, 2012 09:33 PM
Ritory
Nov 22, 2010 04:02 PM
tjay460
Aug 1, 2006 12:52 AM
