Transmission pan
Old Jun 9, 2025 | 09:22 AM
rsylvstr's Avatar
rsylvstr
Transmission pan
2013 F150 5.0
From what I see, the pan is Part Number:BR3Z-7A194-A
As far as the bolts go, I am being told by an independent and my local dealer that the bolts are torque to yield, but I can't find anything online or a schematic that shows that.
Chatting with "Sandeep" at Tasca, they gave me this PN for the bolts, certainly not torque to yield W500214-S437 and should be reusable.
And 7-8 quarts of LV to refill?
Thanks.
Old Jun 9, 2025 | 10:01 PM
B+ squad's Avatar
B+ squad
Old Jun 10, 2025 | 04:13 AM
RLXXI's Avatar
RLXXI
Definitely NOT torque to yield bolts, matter of fact the torque spec on the pan bolts is 12 Nm (106 lb-in) and both the bolts and the pan gasket along with the pan are all reusable if undamaged.
Old Jun 10, 2025 | 12:32 PM
rsylvstr's Avatar
rsylvstr
Originally Posted by B+ squad
Those bolts are not at all torque to yield, I had a regimen that had the pan off about 6 times and never leaked. The bolts and gasket are reusable. Be careful with the torque though, 8mm bolts into an aluminum housing is not very much twisty force before::: snap:::
Yes 7, maybe 8, to do a pan drop and refill. The system is something like 14qts, but you can't get that out by dropping the pan. I did a write up on another post, I can repost them if you'd like.
Edit: I don't understand why you listed the pan p/n, did the old one break or something? Those are also reusable.
Thanks for the info about the bolts.
New pan as I made the mistake adding a Dorman with drain plug. Thing is about ready to rust right through!
Dealer and independent both want $900 to replace it!
Yes, I plan to do myself, although I am not looking forward to refilling.
Old Jun 10, 2025 | 06:17 PM
B+ squad's Avatar
B+ squad
Old Jun 11, 2025 | 11:51 PM
Evan76's Avatar
Evan76
Ill eventually get a ppe pan for my ford. Have one on my cummins.
Yes the fluid and filter change isnt that bad.
dont freak out when you pull drain plug and nothing comes out. These transmissions are under a vacumn. Craziest thing ive ever seen.
Yes pan bolts are basically just snugged up. I think tourge spec is same as spark plugs. Just alittle more than finger tight.
Old Jun 23, 2025 | 03:46 PM
2jhanna's Avatar
2jhanna
just curious, how long did you have your Dorman pan? I installed one a few years ago, and just looked at it, no signs of rust at all. I will be using the drain plug for the first time in a few more weeks, when I'm due an oil change, already have 9 qts of fluid on the shelf.
i still have my OE pan, if I need it.
Old Jun 26, 2025 | 06:13 AM
rsylvstr's Avatar
rsylvstr
leas than two years. They threw the pan out when they replaced it. Another reason I should’ve done it myself.
Old Jun 27, 2025 | 09:42 AM
2jhanna's Avatar
2jhanna
thanks for the response, I just rechecked my pan, no rust, so far, no flaking paint, but I will keep a close eye every oil change. I also checked my service log, Dorman pan, fluid/filter change, sept '21, so almost 4 years ago.
maybe cause I'm in Texas, you ever heard, "everything is better in Texas"!
Old Jun 28, 2025 | 11:47 AM
rsylvstr's Avatar
rsylvstr
when people say “the rust belt” I tell them NY is one of the worst states.
for multiple reasons LOL
Robert Goldie
2009 - 2014 F150
Oct 13, 2020 10:07 PM
blageurt
Ford Truck Parts for Sale
Sep 29, 2016 04:17 PM
99FORD EXPY.
6.7L Power Stroke Diesel
Jul 6, 2016 09:27 AM
bridge
20
Nov 12, 2012 10:43 AM
bluewaveking
Jul 23, 2012 03:46 AM
