AOD trans for 390
Old Dec 6, 2003 | 12:20 AM
Cracker289's Avatar
Cracker289
AOD trans for 390
Hi all, I have a 69 F-100, I am wanting to put in a 390 engine, but I would also like to have overdrive. Is there a later model pickup with an AOD that will bolt up to an older 390?
Old Dec 10, 2003 | 01:09 AM
ACESN8S's Avatar
ACESN8S
Go to http://www.lentechautomatics.com/home.htm
You can expect to pay $2795 for a street tranny that will handle up to 400hp, and it will cost you $3395 for a tranny that handles 400hp to 700hp. Oh yeah, then there's shipping and other options to choose from.
Old Dec 10, 2003 | 01:59 AM
Cracker289's Avatar
Cracker289
I was actually hoping more along the lines of something from a wrecked mid 80's F-350 or something. Will an AOD from a 460 bolt up to a 390? How about a trans from a 351W?
Old Dec 10, 2003 | 02:30 AM
ACESN8S's Avatar
ACESN8S
To my knowledge, limited at best , the FE has it's own bellhousing pattern. The smallblocks have their own pattern, and the 429-460's and the 351M-400M share the bigblock pattern.
The 351M-400M (351C too?) are considered big blocks technically.
If anyone knows something else.....please contribute .
Try this thread also https://www.ford-trucks.com/forums/s...hreadid=176800
Old Dec 11, 2003 | 07:41 PM
mamafedmepaintchips's Avatar
mamafedmepaintchips
FE motors do have their own bolt pattern, and the last production date for FEs was 1976 for trucks and 1971 for cars. The chances look a little slim, but if you find one, please let us know were you got it. Hope that helps a little
Old Dec 11, 2003 | 08:30 PM
BB's Avatar
BB
Hi, we're talking about that in the FE forum right now:
https://www.ford-trucks.com/forums/s...hreadid=180456
https://www.ford-trucks.com/forums/s...hreadid=178907
Also try the search in that forum to help get a little more info.
Barry
Old Dec 11, 2003 | 09:16 PM
CACWBY's Avatar
CACWBY
and talking about it and talking about it and ...
I'd rather do it! I still think that $325 adapter from fb is for a 429/460. It says Big Block, and that does not mean FE BB. As before- the AOD uses Throttle Valve, not vacum, the OD can be turned off by a switch. If switch is ON then OD can be engaged above 55mph by TV Cable Setting, a lot like old manual OD you reach OD speed and lift off gas slightly. You have to have an adapter. And all I know is what I've read about AOD needing to be beefed up to handle higher Torque and HP so I used Lentech - I suspect any Good Trans shop could beef up for your needs for less $$$. I think I could write an article on how much fun it is to have a FE powered 67 truck with an AOD Trans, but I couldn't write a paragraph about the technical aspects of this.
Old Dec 18, 2003 | 09:10 PM
docholiday72tx's Avatar
docholiday72tx
Do you have to have an over drive gear? If not, have you considered a gear swap on your rear end. I have a 73 model truck with a 390 and gas milaege was bad with 3:50 gears. I bought a complete rear end from the wrecking yard with 3:00 gears along with traction lock for $300. Took about an hour to bolt in, and fuel mileage went up about 3 mpg. Much cheaper and easier than O.D.
Old Dec 18, 2003 | 10:10 PM
MW95F250's Avatar
MW95F250
AOD's were never offered on a 460, I believe. The AOD is really not as strong as a C6 and in my opinion, the AOD would be downgrading if you already have a C6 in.
Old Dec 19, 2003 | 09:15 AM
CACWBY's Avatar
CACWBY
True - but can you say "Beef It UP!
The above post is true. But - that is why they Beef up the AOD, and there are 10 second cars many with 460's that have beefed up AOD's. Why - because of the OD part. Not for the strip use, but the drive to and from the strip, or on the Power Tour, or drive from WI to SuperNats. As I've said and many with AOD agree, it's so much fun to do 75 all day with engine purring along at 22-2300rpm instead of 33-3400. For out of the box how much power can it handle comparisions of course the famous C-6 wins hands down. But if you want OD ...
Oh and also what the OD part does is allow you to switch to lower gears, I went from stock 3.25 to a 3.55.
Old Dec 21, 2003 | 06:15 PM
Dodge41's Avatar
Dodge41
460 Engines were offered with an overdrive in the 80's. The trannsmission was called en e4od. Id imagine it would mount to a 390. This is electronically controlled and a real POS tranny in the first place, so you really dont want it. You can use it but you either have to convert to efi or get a control module. If you want an overdrive your best bet is a ford aod or a chevy 700r4. I can say chevy on here right? They make adapters for them to fit. You will probably need to get the tranny built bc the 390 can rip one apart if you have it making alot of hp. Anyways here is a couple of links to the transmission adapters.
http://www.tciauto.com/specialty/adapter_kits.htm
http://www.artcarr.com/
Expect to pay around 300 to 600 dollars for an adapter.
Old Dec 21, 2003 | 09:36 PM
MW95F250's Avatar
MW95F250
Actually the E40D got the internal improvements after May of '95.
Old Dec 21, 2003 | 10:41 PM
f100guy's Avatar
f100guy
the aod has no button to turn off OD. that is the e40d
Old Dec 22, 2003 | 08:15 AM
Dodge41's Avatar
Dodge41
From eveyone i have ever talked to has told me even the new e40d's are still pos. I'd just go with a built 700r4.
Old Dec 22, 2003 | 08:28 AM
MW95F250's Avatar
MW95F250
If behind a diesel, yes, but behind a gas engine, no. I've had no trouble with mine, and neither has my grandfather in his old truck.
It was not designed for a diesel's extra torque, but I've seen them modified where it will take 850lbs. of torque with no trouble.
Do a search for the 11.4 second F-350 Crew Cab thread on here. It has a built E40D in it.
The 700R4 is not a rose either. Think back to the 80's when it came out, you couldn't keep it together much better than the first E40D's.
