I live out in the country in an area where there is little lighting and driving out here at night is really in the dark. I would like to replace my exterior lights on my 2019 F250 Lariat with LEDs, but am not sure what's involved, or what the best source for them would be. Is it a simple swap bulb for bulb, or is more involved? Also, what experiences have you had with which vendors, and what is the ballpark cost for the conversion, from headlights to license plate lights. Look forward to hearing from you do i can move forward. Thanks!
I put the LED bulbs in my halogen factory lights (2018) and it isn’t great. The low beams work ok, but switching on the hi beams, it doesn’t throw the light any better than the low beams. Might even be worse. Coming from a 2014 f 150 with the hid lights, it sucks compared to them.
I went the cheaper route that some posted good reviews with just to see if I would like them. It's been 6 months now and don't regret going with the Phillips. They have better foward lighting than the prior halogen output and lights the front roadway and side some.
Here is from the post did in my maintenance thread in 7.3 gas forum.
I'll also add that I added Diode-dynamics pillar lights and fog lights (post 179).... running back roads with down range brightness for seeing animals isn't a problem now. All posted in that thread.
I never tried the halogen to LED headlight conversion. I did swap LED bulbs into the fog lights, and though the LED fog bulbs were much brighter, the light was not focused and not helpful. Diode Dynamics sells direct replacement LED fog lights that are supposed to be twice as bright as factory halogen fog lights. There are brackets and pod lights you can get from Diode Dynamics, Baja Designs, Rigid, and others that can replace the fog lights with much brighter cube lights. I eventually added four Diode Dynamics SS3 Pro Driving lights, and they are all around super bright focused very good enhancement over even the factory highbeams.
Wow, thanks for the responses! I'm not so much worried about straight ahead, as I have two 150 watt lights mounted on the front bumper (whose brand i can't identify) for those needs.
It's just that when i can't use those, like driving in traffic or in town, I find the stock headlights a little anemic.
For further clarification, I also wanted to replace the running lights, brake and license lights as well. Any takers?
Also in that thread..replaced all lights on the truck with led.
You guys wanting all the extra crap on these trucks including led lights won't be happy till every truck is $100k. Not to mention replacement cost for items. Halogen bulb or led bulb compared to an entire lled light assembly.
i need the extra lumens. Most of my driving is out in the country, with no lighting for miles. I'd prefer not to hit deer and wild hogs, so the further out i can see them, the better.
Changing to led bulbs are much cheaper than buying an entire light assembly.
I also run back roads in open range country. Elk, cows, moose can really ruin your day like deer.
You really want to light up the road add some pillar lights and better fog lights.
