Np435 transmission help
Old Jun 5, 2025 | 06:39 PM
Nathan ozias's Avatar
Nathan ozias
I’m currently rebuilding my np435 transmission for my 1980 ford f-350. I’m almost done but when I measure the clearance between the 3rds speed and syncronizer it’s like way out of spec(.12 when spec is .070-.095) i want to add shims but can’t find any anywhere is there anything else I can do or anywhere I can find shims in stock?
Old Jun 6, 2025 | 06:38 AM
FuzzFace2's Avatar
FuzzFace2
Who did you get the rebuild kit from and I am guessing you checked with them?
Who else have you checked with and is it they done have in stock but can get them or are they N/A as there is a difference between the 2.
Also if they dont list the shims in their sites I would give a call just to make sure they dont have them and ask where you might get some from.
Dave ----
Old Jun 6, 2025 | 08:12 AM
Nathan ozias
I got the rebuild kit from cobra transmission and they don’t have any in stock but it does say they are still available.
Old Jun 6, 2025 | 09:14 AM
FuzzFace2's Avatar
FuzzFace2
Sometimes we just have to order and wait for them to show up.
You can try to google for them and give a call around but if they have them I would just order and wait.
Goood luck
Dave ----
Old Jun 6, 2025 | 09:37 AM
Nathan ozias
Also this isn’t a full rebuild I’m just replacing the seals and bearings. Could it be that the 3rd/4th gear synchro is worn and needs to be replaced?
Old Jun 7, 2025 | 06:00 AM
FuzzFace2's Avatar
FuzzFace2
It must be something with the NP435 as my 3rd / 4th shift is not happy but I bought the transmission used so who knows what it had been thru?
Now I have a BW T18 that this NP435 replaced that is really bad as it has chipped gears and no syncros and why it was replaced.
It is also how I bough the truck.
Dave ----
Old Jun 7, 2025 | 11:13 AM
Franklin2's Avatar
Franklin2
Synchronizers are a normal wear item like the bearings and should be replaced if you have the tranny torn down.
Yankee farmer
Nov 19, 2024 10:44 AM
EdwardNR
Sep 21, 2023 09:10 AM
Brian_ct
Sep 28, 2018 11:27 PM
tigwelder
Dec 28, 2011 03:11 PM
Lodhaseng
Oct 15, 2009 02:17 PM
