Sponsored by: Real Truck
Just A Question
Old Jun 4, 2025 | 10:05 AM
Rick1025's Avatar
Rick1025
Just A Question
I am planning for a 4x4 install on an E350 van. From what I learned. A 2005 and up coil spring F250/350 is the front axle of choice. so; are there differences in different year front axles? dana 60s? brake rotor size? etc. Thanks for any replies/irealize this is a bit off topic.
Old Jun 4, 2025 | 12:47 PM
riderboy1961's Avatar
riderboy1961
From what I have read over the years... I think the "prefered choice" by owners is more the Coil Spring System than a particular axle. Apparently the rigs have a smoother ride with the coil springs.
Solid axle, I believe is considered the strongest.
I am no expert either
Old Jun 4, 2025 | 03:51 PM
Rick1025's Avatar
Rick1025
I was wondering about rotor sizes over the years. Were the brakes upgraded over the years. i am trying to plan for wheel size. I have plenty of 16' and dont know if I can use them or not.
Old Jun 4, 2025 | 05:22 PM
WE3ZS's Avatar
WE3ZS
If using ‘05+ front suspension, then no, after the switch to coil sprung fronts on the 4x4 trucks the brakes got bigger and minimum wheel diameter moved to 17”. The wheel mounting surface also moved outboard about 1.75” at each corner, so the earlier wheels would stick out that much from stock position.
Old Jun 5, 2025 | 07:31 AM
Rick1025's Avatar
Rick1025
Thanks,that was the info I was looking for.
Old Jun 5, 2025 | 07:56 AM
WWR's Avatar
WWR
2013 brakes stepped up.
And don't start threads with generic topics.
UNTAMND
Jun 15, 2016 12:40 PM
Bronco308
1978 - 1996 Big Bronco
Oct 1, 2011 09:42 PM
mrniceguy351
Nov 3, 2010 05:33 PM
pc_2000
Apr 28, 2009 04:59 PM
Boss_358
Jan 18, 2009 02:26 PM
