quad head light
Old Feb 23, 2026 | 10:20 AM
  #31
TestPilot57's Avatar
TestPilot57
Originally Posted by scraprat
Too bad there aren't walls in shopping plazas or some where similar.
Ah, so your mall parking lots get flooded all the time?
Old Feb 23, 2026 | 12:07 PM
  #32
scraprat's Avatar
scraprat
Top Answer: 5
What are you talking about?
Second thought you're best taking the truck in for head light adjustments, better have them check the light fluid so they stay bright.
Old Feb 23, 2026 | 12:28 PM
  #33
sicdrummer27's Avatar
sicdrummer27
Parking lots are slopped for drainage so water does not accumulate. Not level.
Some glasses may help you notice this.
Old Feb 24, 2026 | 04:12 AM
  #34
techrep's Avatar
techrep
Originally Posted by 66Classic96
wrong forum, sorry
gotcha.
Old Feb 24, 2026 | 10:12 AM
  #35
Stonehauler's Avatar
Stonehauler
In general most parking lots (at least in the midwest or mid-atlantic), are "generally" flat-ish". I am not going to say perfectly flat, or that a carpenters level isn't going to show some up/down on it, but in general, it should be "fairly close"
Remember, your target is 25 feet away (C)...or in other words, just a little bit more than another CCLB away from your headlights. In general, most parking lots will have a similar slope within that 45 ft distance (from the back of your tires to the screen as long as your are staying away from the drain areas. THAT SAID...if you are aiming for the "perfect" setup, I agree with the statement that a parking lot isn't level and you won't be able to perfectly calibrate your lights. However, it should serve as a fairly good indicator if one or more of your light is out of whack.
orich
Apr 3, 2015 11:50 AM
bearhugger
Oct 27, 2010 07:27 PM
250 STANG
Sep 6, 2006 09:33 PM
kittyhawk
Jan 26, 2005 08:23 PM
mudguy33
Jan 17, 2005 07:38 PM
