I've been searching the web trying to identify the model # for a holley on an 83 ford camper van with a 460 . I've searched the list number and i am coming up with nothing . The list number stamped is 51t003 , bellow it is 3502 and above it is e3te 9510 rc
I have a leak at the accelerator pump and I'm just looking to get the right diaphram , any help would be much appreciated . I'm thinking it's a 4180 but not certain .
When you look it up in the book use the Ford part number, e3te 9510 rc that will get you the right parts. Some parts of those carburetors are unique when compared to aftermarket Holley but other parts are generic. I think that the acceleration pump diaphragm is one of those generic parts and it is the regular old 30cc one.
perfect thanks . I couldn't find anything solid online and I kept circling back towards that part number . I was going to order one for the sake of trying it since it is cheap enough , this verifies I was on the right track , thanks .
It's basically a 600 CFM Holley with a few emissions mods like adjustable idle mixture needles on the throttle plates
The smart man will
Put steel alcohol needles in it to run todays alky fuel with no sticking needle and seat issues
A couple of things to check are also to make sure that the outlet check valve isn't stuck and that the pump cover is flat. Both of those things can also cause leaks.
