Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
2 speed troubles
Old May 28, 2025 | 08:28 PM
jholland's Avatar
jholland
2 speed troubles
I am having trouble with my 2 speed in my 1972 F600. There is a black wire that attaches to something right behind the speedometer that clicks like a solenoid. What is this? Can anyone tell me where the wiring harness goes? There are three wires to the selector switch and these go into another harness that contains that black wire. Can anyone provide me with a schematic of the wiring? Thanks
JHolland
Old May 28, 2025 | 08:53 PM
85e150's Avatar
85e150
The item behind the speed-o is possibly the device that changes the cable input speed so the speed-o is accurate when the two speed is shifted.
You should have power to the switch and wires back to the axle and shift motor.
I'll try to find a schematic later.
Old May 29, 2025 | 02:29 PM
85e150's Avatar
85e150
From the Tech Threads at the top of this forum:
https://www.ford-trucks.com/forums/1...mechanism.html
That post contains illustrations of the two speed wiring as well as photos of the truck in question and a video of how the electric shift works.
Even though it's an older truck, the two speed and electic shift work pretty much the same way for all model years.
Old May 30, 2025 | 12:55 PM
asavage's Avatar
asavage
FTE Community Team
2-Speed axle wiring: I have scanned the 1973 (which, while different, should be similar to 1972) wiring diagrams for F500-F750, and you can get them from the link posted in the first post of this thread. I don't want to post the link here, because if it changes, I want to be able to change it in one place, not 50 different threads.
It's six large pages.
It shows power from unfused Ignition Switch (Page 3) via wire designation 297, color Black w/Green stripe
To internal harness connection S-701 (Page 4)
Splitter connector C-1001, probably in the dash (Pages 4 & 6)
Protected by Circuit Breaker CB-2 (Page 6)
To the gearshift switch via wire 142 Green (?? There is not "GR" in the color table on Page 1. Gray = GY, so I'm guessing "GR" = Green ??)
Finally, to the axle motor via wire 141 Black (which also splits off to the speedometer cable gearbox) and 143 Red, via several connectors along the way.
Here's a cut down/marked-up Page 6 that shows the meat of the 2-speed motor wiring:
Old May 31, 2025 | 01:15 PM
asavage's Avatar
asavage
FTE Community Team
IDK why this shows the fuse panel on the left side; every one I've seen is on the right kick panel.
Note the motor's ground location on the frame, near washer 34940-S. That ground, and the two connections next to it, form "connector C-1010" and would be an excellent place to check. Ground connections like that, exposed to road conditions, are a great place to begin. You have power from the gearshift switch to the speedo gearbox, so I'd check downstream, and that would be my first choice. On the frame, directly forward of the shift motor.
Old Jun 9, 2025 | 09:40 PM
jholland's Avatar
jholland
Got everything fixed. Found one broken wire (the green one) in the harness at the bottom of the shifter. Purchased a new harness from NAPA and it works fine. Thanks to everyone who responded.
JHolland
tsimpson4472
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Oct 15, 2021 10:08 AM
AMERICA_
Mar 17, 2015 10:27 PM
cbablair
Nov 28, 2012 02:57 PM
ssj7kids
Jun 23, 2007 09:18 PM
xKirkx
1978 - 1996 Big Bronco
Feb 9, 2004 01:13 AM
