Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Leer Wiring
Old Sep 17, 2021 | 07:41 AM
tsimpson4472's Avatar
tsimpson4472
Leer Wiring
I am getting ready to move my Leer 122 from my old truck to the new one and ran into an unexpected wire in the harness. A majority of the wiring harness is tapped into the driver's side tail light wiring, except for this connection to this purple wire. Anybody know what this purple wire is for? I am going to cut the red wire to remove the Leer harness - any problems with that? Thanks!~
Old Sep 19, 2021 | 07:20 PM
Cuzzo1981's Avatar
Cuzzo1981
Did you follow that purple wire and is it attached to the red wire? I just picked up a 100xr and the bed light on the topper was run all the way to battery. I just cut the 4 wires coming from the plug attached to the inside left of the topper as that plug wouldn't fit thru the hole in the bed. Don't know if this helps
Old Sep 20, 2021 | 06:49 AM
tsimpson4472
I didn't chase it beyond the spare tire, but I still have the truck and can take a look. From what you said, the purple/red wire is for the cap's dome light - that makes sense. I actually forgot that it had one! I have never used it. I cut the red wire right at the connector and pulled the harness out. Thanks for getting back to me.
Old Oct 15, 2021 | 10:08 AM
clarkbre's Avatar
clarkbre
I know this is a bit late but the single wire by the spare tire provides power to the "center high mount stop light"......3rd brake light.
Since the left and right tail lights have a shared turn signal/brake light on the same circuit, the 3rd brake light has an individual wire. This prevents the 3rd brake light from blinking like a turn signal had it been tapped into the left or rear tail light.
On the 100XR (and many others) the electrical components share a common ground but get a positive signal from different sources.
MB1776
Oct 19, 2023 05:05 PM
CTroxtell
Nov 7, 2019 06:39 PM
woodsmoke
May 15, 2015 11:09 PM
dferrell5
Oct 24, 2013 10:24 AM
