Desperately need help!
Old Dec 6, 2003 | 01:14 PM
BlueTorpedo85's Avatar
BlueTorpedo85
Well, it was the alternator, got the truck tested and thats the problem. At least I know whats wrong with it, now all thats left is everything. This is my first alternator, but I have replaced many other parts, so this shouldn't be too bad. Thanks again for all your help, you all made this a whoooole lot easier.
Old Dec 8, 2003 | 12:29 PM
BlueTorpedo85
Ok ok, i got the alternator in, truck runs fine, but the gauge for the battery seems a little goofy, it's leaning toward charge, which i guess is ok, but when i put the lights on, the gauge flickers, then goes back to where it was. Im guessing this is normal cause the battery is charging, right?
Old Dec 8, 2003 | 01:15 PM
stepman's Avatar
stepman
That's normal as long as it's not too far towards charge. Measure your batt volts when it's running. If it's over 14.5, you may want to change the regulator too.
