Yes, but is more flow than it should be? Again bypass filtration needs low flow to work correctly and not pull too much oil from the main system and is generally restricted on the outlet side of the filters, you may have opened up that restriction.
More flow through the bypass system is not a good thing.
That's what I was thinking... too much flow through the bypass filter system.
