Oil & Lubrication
Oil drain plug gaskets??
Old May 24, 2025 | 08:32 PM
Brian Ski 44's Avatar
Brian Ski 44
Does Ford have any kind of standard on their drain plug gaskets? My neighbor has a 03 F150 4.2 with a drip. I would like to get a gasket ahead of time. I mostly work on Ford so would like to have a few spares around. Ford 460, 7.3 diesel. A few Escapes. Is there any standards? I see some 14mm and 12mm gaskets and some kits that cover a few. I don't want to pay a lot for a bunch of stuff I will never use, But a kit sounds good. (Maybe with a couple drain plugs??? If they are kind of standard.)
I just found this one on a Zon search.
Zon gasket kit. Zon gasket kit.
Old May 26, 2025 | 12:31 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
It would probably be most efficient to browse Rockauto.com for oil drain plug gaskets for the respective year/make/model/engine vehicles you're talking about.
I did find some commonality between oil plug gaskets for a 2003 F-150 4.2 and a 1995 F-350 7.5 , but no commonality between these and a 2010 Escape.
Old May 29, 2025 | 06:50 PM
Brian Ski 44
Good call... Gaskets are a little common, but the drain plugs are all over the place. Quite a few different diameters and thread pitches.
Old Jun 1, 2025 | 06:38 PM
CathedralCub
FTE Community Team
It's amazing that the world hasn't gotten together and figured this one out like they did with oxygen sensors!
Last edited by CathedralCub; Jun 1, 2025 at 06:38 PM. Reason: Demoted an uppercase letter to a normal lowly lowercase letter
Old Jun 1, 2025 | 07:40 PM
Brian Ski 44
It would make it too easy. I just got the gasket set I posted above. Nice set, looks like it will cover most of the common stuff. The box is a little cheap. The gaskets were a bit mixed up from bouncing in shipping.
Long Haul
Nov 2, 2014 12:43 AM
hermancm
Jul 22, 2013 08:17 PM
redman84
16
Sep 5, 2012 12:03 PM
skl
6.4L Power Stroke Diesel
Nov 10, 2007 10:04 PM
reddhawk
Garage & Workshop
Aug 14, 2002 04:44 PM
