Would you buy a used truck with a lift kit?
Old May 23, 2025 | 10:32 AM
muhford's Avatar
muhford
https://stlouis.craigslist.org/cto/d...852226591.html
The only (decent) truck within 3 hour drive is this one. But it has a 2 inch suspension lift kit installed by the owner. I greatly dislike truck modifications but this is the only truck I can find.
Any thoughts? Would you buy a used truck with a lift kit?
Old May 24, 2025 | 11:22 AM
Johnny Paycheck's Avatar
Johnny Paycheck
I wouldn’t turn that down if it otherwise checks out. I’ve seen way worse on CL and other sites that I would look away from. Stuff I’d need an extension ladder to get into. No dice there.
Old May 25, 2025 | 06:39 AM
techrep's Avatar
techrep
single cab and no inside pics... seems over priced and needs new rubber. The lift is no problem as long as it was done correctly and all the suspension is solid.
Old Jun 1, 2025 | 06:57 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Not all lift kits are equal. That one doesn't look bad. Get the seller's info for what lift kit it is so you can undo it.
Will Chiello
Feb 17, 2011 12:37 AM
snubber
Nov 1, 2008 11:54 PM
jake00
Sep 28, 2006 09:30 PM
