ECM Pinouts for MAF conversion?
Old May 20, 2025 | 07:13 PM
gman1377's Avatar
gman1377
Trailering
I'm converting my 92 half-ton 5.8L E4OD from speed density to MAF and I've searched for some decent ECM pinouts to no avail. If anyone has some and are willing to share or can lead me to some that would be great.
Also, I've seen some say the MAF trucks are sequential injection while others say that are still batch? I'm not sure if it would matter, would I have to change pins or add wires if it was sequential?
If you have any more information I should know about this conversion would help me a ton, thanks.
Old May 20, 2025 | 07:34 PM
Conanski's Avatar
Conanski
Why? What PCM do you have?
I have pinouts
All MAF Ford trucks are sequential injection. Yes it matters. Yes you have to move pins and add wires.
Old May 20, 2025 | 09:26 PM
Scndsin's Avatar
Scndsin
What is your goal, cause I've done all the steps.
I modded my factory harness to MAF, then complete under hood harness swap, then went pimpxshift by Stinger.
Unless you can noodle the factory tuning with Moates or tweecer in whatever state they exist these days, just leave the current SD & go with the pimpx.
What kind of trans?
Old May 20, 2025 | 11:12 PM
gman1377's Avatar
gman1377
Trailering
I have pinouts
I'm planning on power mods in the future and working around speed density is a total pain. Switching to MAF makes it easier to upgrade in the future.
I'd have to check specifically which computer I have (i assume you mean the model/part nunber on the ECM sticker) but like I said its just for a 5.8L auto E4OD.
Good to know about the sequential injection. Thanks.
I'd like to get those pinouts too, let me know if you need more information from me.
Old May 20, 2025 | 11:18 PM
gman1377's Avatar
gman1377
Trailering
What kind of trans?
My goal is to make it easier for power mods in the future, like a bigger cam or something. The speed density isn't happy with changes in vacuum things are just easier with a MAF setup. Plus I've heard the MAF setup gets a slight bump in power and fuel efficiency. Its an E4OD btw.
I looked into pimpx, that's a really neat solution! Very pricey though... I'm more of a budget minded kinda guy 😓
Old May 20, 2025 | 11:39 PM
gman1377's Avatar
gman1377
Trailering
The more I read about this pimpxshift the more I like it. Maybe its worth saving up a few paychecks.
Old May 21, 2025 | 12:44 AM
Scndsin's Avatar
Scndsin
Don't get hung up on either the MAF, sequential or SD.
I run sequential & SD simply because I'd already done the conversion to sequential when I went pimp.
Batch fire SD will support pretty much any HP levels you can think of just fine.
I was cheap too. I got approximately 300-ish HP out of a mild GT40 headed 5.8 build with the stock SD & additional 10-15 HP MAF no tuning.
Taught me a lot, but it would have been a whole lot easier if I'd just dropped the $1400 (no idea current cost) for the pimpxshift.
Old May 21, 2025 | 12:57 AM
gman1377's Avatar
gman1377
Trailering
Thats good to know about SD, I was looking to do similar power mods that you have. But one of the main things I was looking for out of the MAF conversion too was the bump in efficiency from sequential injection, since fuel isnt being wasted nearly as much. Believe me any bit of mpgs help on these trucks lol
Old May 21, 2025 | 01:25 AM
Scndsin's Avatar
Scndsin
That's just it. The difference in efficiency between batch/sequential is miniscule & will out-weigh the other at different points of the RPM spectrum & engine operation.
That extra 6 wires for the injectors + MAF wires & other wiring relocation adds up & makes for additional failure points you really don't want to introduce
Just go with what you have & the bare minimum wiring modifications, tune to your hearts content & then change to MAF/sequential if/when you learn all the ropes.
This system will run ANYTHING from 2-16 cylinders of any displacement you can hook-up to a 60-pin EEC-IV connector.
Trust me on this.
Old May 21, 2025 | 08:44 AM
Hit Man X's Avatar
Hit Man X
Even if you are MAF, the PCM can only tolerate so much in change before...yep, you have to tune it accordingly. In the late 90s and early 00s, sure it was the way to go. I converted my '88 to it with the old FMS kit, worked fine for my needs at the time. The MS unit by Stinger is the most modern way to go and will do whatever you want.
Old May 21, 2025 | 09:44 AM
wwhite's Avatar
wwhite
PimpX i think default is SD, and can be changed to support MAF or Alfa-N.
QuarterHorse and SD is better supported than QuarterHorse and MAF.
You only need to tune if your mods are over and above. I'd wait till you add the power adders before thinking of swapping what you already have.
I run SD. The swap to MAF was done in the past because no one knew how to deal with SD. That is not the case today, and is probably a waste of money and or a headache if you've never done a swap before.
Old May 21, 2025 | 12:54 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Any of these you better know what you are doing, they talk way up the engineering ladder, assuming you already know, but you dont, poke around ant look at all three stinger, tweecer, quaterhorse, you'll see.
And -->The TwEECer -- Ford EEC user programmable module
Old May 21, 2025 | 01:27 PM
Truckwardo's Avatar
Truckwardo
Micro and Mega Squirt can run E85 when you add the 70 dollar Delphi sensor. That's power right there. It's a budget option.
Old May 21, 2025 | 01:31 PM
wwhite's Avatar
wwhite
LOL, the engine runs on E85, the tuners run on battery juice.
The micro/mega/QH/Pimp, etc can be tuned to make the engine run on whatever.
You could even tune them to run 100 Low Lead if you had access. That's power, and not a budget option.
Old May 21, 2025 | 01:35 PM
Truckwardo's Avatar
Truckwardo
microsquirt is cheap. Programming isn't. But the unit itself is cheap. If you want water methanol get the Megasquirt. Most other stand alone costs more.
