Turbo cleaners?
Old May 20, 2025 | 02:54 PM
Frank79's Avatar
Frank79
Turbo cleaners?
I just came across a google link that there are additives for cleaning your vanes on the turbo. Is this snake oil Or does it really work? I know some folks are up in the air about adding additives to their fuel tank to clean out injectors and what not.
i also read that it’s a very good idea to always keep your engine break turned on so it does not build up a lot of carbon on the vanes?
I’ve had my diesel for over five years and never knew about these two situations 🤨
Old May 20, 2025 | 03:31 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Never heard of any additive that would clean the soot off the turbo actuator sleeve.
But, the second point is a big YES!
Run the exhaust brake as much as you can, the exhaust brake uses the variable turbo actuator sleeve to close off the turbo to cause the exhaust braking effect.
So, running the exhaust brake makes the sleeve run through its full travel, helping to keep the soot from building up on it and blocking it.
Old May 20, 2025 | 03:39 PM
Frank79's Avatar
Frank79
now all these ads are popping up since I started reading about it 🤦‍♂️
https://www.jlmlubricantsus.com/prod...%20effectively.
Old May 20, 2025 | 06:05 PM
scraprat's Avatar
scraprat
Top Answer: 5
Don't read the ads with ED or you'll be in the same boat as another poster that never even looked at those ads. LOL
Old May 20, 2025 | 09:04 PM
WXboy's Avatar
WXboy
Like the CRC GDI and Turbo Cleaner in the aerosol cans? I have some. I'm just scared to use it. LOL. So it sits on the shelf.....
Old May 20, 2025 | 09:40 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
How would anything in an aerosol can do anything for an internal turbo issue?
Old May 21, 2025 | 06:04 AM
99powerstrokedF250's Avatar
99powerstrokedF250
You'd have to disassemble (at least partially) the turbo exhaust pipe and spray it inside I would guess. Still not sure it would do much.
To OP, the biggest things you can do to prevent soot build up in the turbo is use the engine brake (even the auto setting) and RUN THAT THING. Heat burns off soot, believe it or not.
Old May 21, 2025 | 06:36 AM
WXboy's Avatar
WXboy
Who said anything about an internal issue? The OP says he wanted to CLEAN the turbo vanes, and that's exactly what the CRC cleaner does. Instructions clearly state just run the engine and spray it in, avoiding getting it onto the MAF sensor which may require removing the air filter temporarily.
Old May 21, 2025 | 07:07 AM
Frank79's Avatar
Frank79
what’s the auto setting? I just have a button on the console I have to push every time I start the enging to turn the brake on/off.
Old May 21, 2025 | 07:35 AM
JD2020F-350's Avatar
JD2020F-350
4wd Low
When you push that button twice an "A" will appear in the icon on your dash light. That mode helps hold your set speed .
Old May 21, 2025 | 07:55 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The variable vane mechanism is INSIDE the turbo on the exhaust side of it, thus an internal issue.
Old May 21, 2025 | 08:23 AM
acdii's Avatar
acdii
My 24 uses the exhaust brake all the time without me pressing any buttons. Unlike the 2019, I can hear and feel it. If a fuel additive is claimed to reduce soot, thats what you would use to keep soot down in the turbo. The intake vanes should be clean unless there is too much oil being drawn out of the ccv. It will take a lot more than spraying into the intake if thats the case.
Old May 21, 2025 | 09:50 AM
WXboy's Avatar
WXboy
If soot is getting on it, then air is getting on it. And if air is getting on it, then a cleaning product like CRC would get on it when sprayed in. I still don't follow. OP asked about cleaning the vanes in his turbo, correct?
Old May 21, 2025 | 11:36 AM
acdii's Avatar
acdii
You going to pull the pipes off the back of the turbo to clean it? OP does need to clarify his question so we aren't ASSuming. Washing down the vanes, simple, remove the intake and spray away, provided his definition of vanes are the ones sucking in air and compressing it.
Old May 21, 2025 | 12:09 PM
99powerstrokedF250
Only way this can be is if you've used Forscan to permanently enable the exhaust brake. Mine will stay on if I am only out of it for a short period of time (less than half an hour), otherwise it defaults to off and I have to press the button twice for automatic exhaust braking.
