352 Jetting
352 Jetting
The 360 in my '75 dropped a valve and busted the block. I had a 352 block in storage, used it to rebuild the engine. Stock .040" over 352 rebuild other than a Crane RV Cam 343902 that the 360 already had in it. (Duration 260/272, Lift .501/.533), roller timing set (not retarded) and a Pertronix electronic distributor.
It still uses the Motorcraft 2-barrel carb, currently with 069 jetting.
It is running very lean, any suggestions on jetting? Or do I need a different carb?
Thanks,
Jim
Thanks,
Jim
I think that's why I would start on the idle feed. It probably isn't on the jet at all most of the time at part throttle and a thou or two can make all the difference especially with a cam that has a bit more duration.
1996_5.8
Feb 2, 2018 09:10 PM
saskpwr
25
Jan 14, 2011 04:54 AM
bshackelford711
Apr 14, 2005 12:58 AM
Azguy54
May 15, 2004 10:55 PM
