Sponsored by: Auxito
Wiring problem
Old May 17, 2025 | 10:51 PM
Anderson96's Avatar
Anderson96
1st Gear
Wiring problem
Im having a issue with my 97 Ford F-150 I've put 2 alternators on it and changed the 2 fuses on the fire wall put a new battery and a solenoid on it and fixed a ground on the passenger frame rail and I still have a issue with the battery gauge going from were it's supposed to be and it will drop down to 8 after a while going down the road and I started the truck a little bit ago to move it and the battery gauge was still at 8
Old May 18, 2025 | 09:29 AM
projectSHO89's Avatar
projectSHO89
Other than replacing parts, have you done any actual troubleshooting?
Observed the BATT/CHARGE light in the instrument cluster?
Checked the fuse in the I circuit (F16 or F19, I think)?
Old May 18, 2025 | 10:41 AM
BareBonesXL's Avatar
BareBonesXL
If the little battery symbol lights up when it happens it might be a charging problem. If it's just the needle it might be a gauge or cluster problem.
Measure voltage at the battery if you can, when the needle is at 8. Even though, the engine wouldn't run if the voltage was really 8. That would be a completely dead battery. It's probably a gauge or cluster problem.
PNGento
2021+ F150
Jan 21, 2024 07:33 PM
YerBoy!
1997 - 2003 F150
Sep 24, 2022 04:28 PM
leonharu
Jun 7, 2019 04:22 PM
ROMAN BROLL
Flathead V8 & Flathead 6
Oct 27, 2008 04:52 PM
D-ranged2.5
1983 - 2012 Ranger & B-Series
Sep 21, 2005 07:11 AM
