351w head to block surface
Old May 20, 2025 | 08:49 PM
Truckbuck's Avatar
Truckbuck
I know this is kinda deviating from the original purpose of the thread, but figured I'd ask.
I replaced the rear main seal on this engine when I put it back together, but within a couple of months it was leaking again. I am looking into a repair sleeve for the crankshaft, there are some grooves in the crank, but I have seen some varying opinions on these. Is this something I should look into? I may have just ruined the seal by installing it wrong, I used some oil on the sealing surface and put it in gently, but I have never installed one before. The leaking rear main seal may just be a curse and you can never get rid of it. *shrug.
Old May 21, 2025 | 09:00 AM
1Butcher's Avatar
1Butcher
PTFE seals are supposed to be installed dry. What type of seal did you put in.
To date, I have never needed a sleeve to fix a leak. Typically leaks that reoccur are operator error.
Old May 21, 2025 | 04:46 PM
Truckbuck's Avatar
Truckbuck
Nope is it was just a plain old seal. I imagine I messed it up putting it in.
CPB1
May 9, 2021 12:13 PM
Budro574
Oct 8, 2020 02:44 PM
fordka
Jul 26, 2014 09:44 PM
CharlieLed
Jun 25, 2010 09:52 AM
MARC
Oct 11, 2004 09:35 PM
