Code 22, failed MAP sensor? (Fixed)
Old May 14, 2025 | 01:57 PM
Junktownbill99's Avatar
Junktownbill99
My truck was running very well (no codes) and then suddenly I believe I heard a pop, and it doesn't run well, (jerky/high idle) and I've got code 22. The vacuum line looked good, so I don't think it's that.
If it means anything, I've been hearing a single pop when I cold start it recently, which I figured might be a loose bolt or something.
Can I use a MAP from a 351? (302 here)
Old May 14, 2025 | 02:00 PM
rla2005's Avatar
rla2005
Same MAP sensor is used for the 4.9/5.0/5.8/7.5 L engines. You may find different part numbers, but they function the same with the same frequency range.
Old May 14, 2025 | 02:05 PM
Junktownbill99
Ok, Ill see if I can go grab one from a parts truck, thanks.
Old May 14, 2025 | 02:53 PM
Junktownbill99
Update: I'm starting to believe I'm losing vacuum somewhere else, both the sensor and line are fully intact, and it's behaving like a massive vacuum leak.
Old May 14, 2025 | 03:35 PM
Junktownbill99
Replaced my brake booster vacuum hose, and it seems to be running good again, no more CEL.
Old May 16, 2025 | 03:45 AM
BluFalcon's Avatar
BluFalcon
6th Gear
Might be time to just start going through vacuum hoses and replacing them one at a time. If one was old enough to have a problem, so are the others. And it's fairly cheap/easy to do if you just buy a couple of feet of the correct hose sizes rather than trying to find specific parts.
Old May 16, 2025 | 12:06 PM
Junktownbill99
I agree, I'm looking to fix up the crumbled HVAC line next.
Obsdanny17
35
May 25, 2023 05:48 PM
48kenworth
Feb 6, 2022 07:43 AM
skidoorulz
Jun 24, 2016 09:43 PM
Larry NCKS
6.4L Power Stroke Diesel
Jan 3, 2010 05:52 AM
riffraff
May 12, 2002 09:49 AM
