Temp indicator still going up and down
Old Dec 10, 2003 | 04:14 PM
broncoray's Avatar
broncoray
Ok, this good be.
Tomorrow is "D" day so I keep ypu posted.
Ray
Old Dec 11, 2003 | 03:06 PM
broncoray's Avatar
broncoray
Well invested a lot of money today without any success.
Changed the radiator, flushed the system, put in new antifreeze coolant, and cleaned the condenser in front of the radiator and nothing changed.
The only thing improved is that the temp indicator returns quicker to normal level at idle.
Also checked the timing of the engine and pressure tested the coolant system
Ray
Old Dec 11, 2003 | 08:56 PM
Ultramagdan's Avatar
Ultramagdan
The pressure check come out ok?
That then leads us back to the water pump. Can you pull a hose off the pump and check the vanes on the pump?
Old Dec 12, 2003 | 05:33 AM
broncoray's Avatar
broncoray
There is one thing that also I can not place.
When driving there is coming up a loud howling from I think the front of the engine.
It start at a low level is then getting louder and louder for a view seconds, then it goose away when the rpm drops below 1700. Again this is not constant but it repeats, it doesn’t matter if the engine is cold or hot. Sometimes I drive for one hour and it is not present, other times just a view minutes after driving. I don’t know if this is some bearing or other vacuum problem and if this has something to do with the temp.
Old Dec 12, 2003 | 05:39 AM
broncoray's Avatar
broncoray
The pressure check did came out ok.
Old Dec 12, 2003 | 09:34 AM
broncoray's Avatar
broncoray
Dan,
I need a new AC condenser because my replacement is also broken, do you now anyone how ships from the US into Switzerland, I asked most part suppliers I good find but they don’t.
Ray
Old Dec 12, 2003 | 03:47 PM
99xlt4.04x4's Avatar
99xlt4.04x4
I posted on your other thread too but here goes. I have a 99 4.0 with the same problem. It overheats about 2 or 3 minutes after i start it. It stays hot for 10-15 seconds and then returns to normal temp. I heard of a valve that sends hot water back to the block before it circulates throught the radiator (to help warm the engine quicker). I dont remember where i read that but i think it was this site. Well anyways check that out and see if there even is one on your truck. If this helps let e know so i can try to fox mine.
Rick94110
Aug 21, 2016 12:45 PM
DSMMH
Aug 25, 2014 07:18 AM
Darthange
1983 - 2012 Ranger & B-Series
29
Feb 7, 2005 04:27 AM
ricky1978
1978 - 1996 Big Bronco
Oct 3, 2004 12:02 PM
broncoray
Bronco II
Dec 31, 2003 03:14 PM
