352 engine
Old May 14, 2025 | 09:41 AM
88frankiejr's Avatar
88frankiejr
1st Gear
352 engine
I have a 1966 F100 long bed with a blown 352cu.in. manual trans will a 460cu.in. fit?
Old May 14, 2025 | 01:26 PM
Crop Duster's Avatar
Crop Duster
Yes, a 460 will fit, but you will have to change everything from the radiator to the driveshaft. The easiest and likely the cheapest in the end would be to buy a reman 390. It would bolt right up to what you have now. Ford 6.4 390 Premium Long Block 1965-1976 - NO CORE REQUIRED - 1 Year Limited Warranty
Old May 18, 2025 | 04:12 PM
jalls1's Avatar
jalls1
Just an aside, my father had a 1970 Ford F250 with a 460 engine when he bought it from the dealer. My brother inherited it when he died. My brother had it for about 8 months before he GAVE it away. It was kinda beat up, but worse, he said he could watch the fuel gauge go from full to empty while driving it short distances. He couldn't afford the gas it took.
Old May 24, 2025 | 08:08 PM
Amish65F100's Avatar
Amish65F100
Like Crop Duster said, it's doable, but a lot needs to be changed. The 460 takes up a lot of space under the hood as well.
Old May 28, 2025 | 05:41 PM
brandosford's Avatar
brandosford
4wd Low
88frankiejr, I have a GT390 engine for sale , where are you located ??
Old May 30, 2025 | 09:32 AM
8Line's Avatar
8Line
totally possible. I have a 429 in my '66. (same 385 series engine as a 460)
can probably find a radiator pretty cheap that will work great, and then it's a matter of the engine mounts, maybe trans mount and drive shaft.
Check out my build thread HERE, scroll down on the first page for links to my engine mount install. I went with Ford OEM mounts for that engine; there are plenty of aftermarket options slightly cheaper but require some drilling into the crossmember. I was fortunate and had all of the holes from factory.
Mx28376
1961 - 1963 F100 Unibody
May 7, 2013 11:33 PM
srameyga02
Feb 17, 2011 04:37 AM
jimi
Sep 2, 2007 05:54 AM
CHAWKINS4297
Dec 29, 2005 03:21 PM
