74 f100 shifting problem
Old May 14, 2025 | 04:30 AM
rensfokkink's Avatar
rensfokkink
3rd Gear
74 F100 wouldnt shift. D stays in 1st. Manual 2nd gear works
Cammed engine makes about 13" vacuum. Too low for the vacuum modulator, so i thought that was the problem. Removed the pin from the modulator, now it shifts to second at about 4500 RPMS.
shouldnt it shift very quick without modulator?
Kickdown cable is removed so that isnt the problem,
any clues?
Old May 15, 2025 | 10:36 AM
FuzzFace2's Avatar
FuzzFace2
What motor & trans but as a guess it is a C6?
My clue it is the kick down cable arm in the "kick down" position.
Move it to the other end or better yet hook it back up.
Dave ----
Old May 15, 2025 | 11:08 AM
tbear853's Avatar
tbear853
If no modulator, then the trans sees no vacuum, like would be at WOT ... and would only shift when the governor said to, because of high rpms .... essentially acting just like the kick down was shoved all the way, even when it ain't.
4,500 rpms sounds about right for a factory set up governor.
rensfokkink
Apr 24, 2025 06:46 PM
FordTrucksKickGM
Oct 27, 2022 09:42 AM
-Ross-
Sep 20, 2013 03:33 PM
Old Ford Blue
May 26, 2008 08:30 PM
Ratsmoker
Mar 7, 2001 08:05 AM
