EGR stealth?
Old May 13, 2025 | 08:19 PM
venexor's Avatar
venexor
4th Gear
EGR stealth?
best options that don’t necessarily involve welding? Maybe plugs? For a 2004 late model
Old May 13, 2025 | 08:46 PM
AK4x4's Avatar
AK4x4
I would recomend that you keep the truck legal, and install the BPD EGR cooler and some Gearhead tunes. my .02, Russ
Old May 14, 2025 | 07:11 AM
Baylinerchuck's Avatar
Baylinerchuck
On the exhaust side I believe others have used plugs with success. You can also use thin plates and gaskets. I’d still be concerned about an eventual coolant leak on the intake side. If you weld and the cooler fills with coolant, who cares. I still prefer the ghost option + valve. Just keep in mind doing this may set codes and possibly a CEL. Being on this forum and this discussion coming up, it seems hit or miss as far as the PCM setting codes. My ‘05 never did set codes, others have. Good luck.
Old May 14, 2025 | 08:24 AM
TooManyToys.'s Avatar
TooManyToys.
An unlisted video. Use both; many have. I had to remove background music due to copyright.
Old May 14, 2025 | 10:45 AM
venexor's Avatar
venexor
4th Gear
https://youtu.be/xiRP2bEk9Nw
I love your delete set up, it’s what I was leaning towards myself when I saw you say it on another thread. I was fortunate enough to find two stainless steel freeze plugs I’m going to shove into the egr and then I think imma use your McCaster idea to seal off the up pipe. I have a Bd up pipe with the flange but no scoop thankfully. Should all work together very well
Old May 14, 2025 | 07:02 PM
TooManyToys.
Before ordering the core plug, check the diameter of the BP up pipe. Also, note that the core plugs I selected are much thicker than the common cup-shaped freeze plugs that were commonly used before.
Old May 15, 2025 | 10:28 AM
venexor's Avatar
venexor
4th Gear
core plug as in the up pipe block off plate? I got 35mm and 30mm to plug the EGR cooler like everyone recommended me to do, just in stainless instead of the usual steel plugs.
Doc Juju
Apr 28, 2022 09:18 AM
reluctantfiver
6.4L Power Stroke Diesel
Oct 9, 2019 10:13 PM
Poorboy04
Apr 22, 2013 08:05 PM
bigsnyder
North Carolina Chapter
Jul 10, 2010 07:30 AM
badbrad60
Mar 7, 2008 08:27 AM
