Tire size recommendation?
Old May 12, 2025 | 10:11 AM
Outdoorboy26's Avatar
Outdoorboy26
Hey guys. Looking for recommendations for tire size for my stock 2000 250 7.3 2WD. General purpose driving - highway mostly. I'll rarely tow a 37-foot travel trailer. Any ideas are appreciated.
Old May 12, 2025 | 11:15 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Stock size.
I run 265/75/16 in a Cooper STT/MAXX for towing heavy and traction in most road/off road conditions and am on track to get 70,000 miles out of them.
I average 12 MPG towing the 5th wheel and 18.5 MPG unloaded with 3.73 gears.
Good enough for me.
Old May 12, 2025 | 12:30 PM
udsuth78's Avatar
udsuth78
I like the tall skinny look myself so a 235/85r16 or 255/85r16 is what I look for. Not for everyone though and those 255/85's are only available in 2 flavors last I looked and are pricey.
Old May 12, 2025 | 12:35 PM
bwguardian's Avatar
bwguardian
I ran 285/75/16 E load range on stock wheels for many years on both trucks...00 Excursion 2wd and 00 F350 4wd. Last year I moved both trucks over to 18" wheels...oem 1 year (04) only...wheels given there's more tire choices.
Old May 12, 2025 | 12:45 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I was a huge fan of the 255/85R16s until the only offerings were mud tires (and the price went stupid).
I recommend sticking with either of the factory options for a SRW pickup of the era: 235/85R16 or 265/75R16. They're the same diameter but the 265 is a touch over an inch wider.
Old May 12, 2025 | 04:11 PM
gunnellett's Avatar
gunnellett
I run 255/85/16 on an OBS crew cab 4X4.
Been through 4 different manufacturers of this size.
I always wanted the Toyo M55 but kept going with something else cause the price just always seemed crazy high to me.
After not being quiet satisfied with the look of those other 255/85/16 tires and how the tread wore, I finally bit the bullet and went with the M55. I wish I had gone with the M55 from the get go. They are way better wearing as far as the tread goes than the others and I feel they look much better. I'm not into the tread going up the sidewall look. The M55 has a much cleaner straight, tall, skinnier look that I am looking for.
Be warned though, they ride like a solid forklift tire! I don't mind though, they are in a 30 year old truck built to work!
Old May 12, 2025 | 08:07 PM
INFRNL's Avatar
INFRNL
My vote would probably be the 265/75 option on a 2wd
Old May 13, 2025 | 07:30 AM
AdamDenver's Avatar
AdamDenver
I'm running Michelin Agilis CrossClimate LT265 75R16. Good traction and good wear. For a tire, it's tough to beat a Michelin.
Old May 13, 2025 | 07:44 AM
MD_7.three's Avatar
MD_7.three
I have a 99 2wd. Installed 2" leveling kit up front, run 285/75r16's now on OEM aluminum wheels, before I had run a similar diameter tire on 18" take-offs from a 2015 F250 but had to run 2" spacers. I pull a 38' 10k trailer just fine with stock 3.73 gears and just a hydra tuner running a 70hp tow tune.
Old May 13, 2025 | 09:05 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Keep it stock.
235/85r16's can be found just about anywhere, anytime.
7.3dually0080
May 14, 2025 07:57 AM
Pyrate7
2015 - 2020 F150
Jul 4, 2024 03:55 PM
cws10190
Apr 25, 2012 10:02 AM
xman7896
May 23, 2004 05:00 PM
