'17 phone conectivity issues
Old May 8, 2025 | 08:13 AM
Gwilkrrs's Avatar
Gwilkrrs
so sync 3 truck. while on phone calls the truck drops the connection and goes to the phone, then the phone connects with the truck and goes thru the speakers again. happens intermediately during calls. always in open areas and never had issue before so its not "tree releated"
when i run forscan diagnostics every 3rd time it pops up no apim
i clear code and all is good for 3 cycles then it pops up again
thoughts?
Old May 8, 2025 | 02:02 PM
BC2019F250's Avatar
BC2019F250
Is your Sync 3 running the most current software update?
Old May 8, 2025 | 02:10 PM
Gwilkrrs's Avatar
Gwilkrrs
Not sure
Old May 8, 2025 | 06:08 PM
BC2019F250's Avatar
BC2019F250
3.4 is the current build. You might look into updating the system to fix connection issues.
Old May 9, 2025 | 04:04 AM
JFH52's Avatar
JFH52
Is your phone connected through USB at the same time? My truck seemed to have conflict between bluetooth and the USB. I have Sync 3.0. Remove phone cable and try.
Old May 9, 2025 | 05:59 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I would agree with updating all software, both on your Sync and your phone. GENERALLY that at least helps the situation.
As for why it keeps showing 'no apim' every few cycles...that sounds like a different issue that could be the root cause of this one if software updates don't fix it.
Old May 9, 2025 | 06:52 AM
Gwilkrrs's Avatar
Gwilkrrs
ok-
i guess i will search how to upgrade sync.........
thanks
Old May 12, 2025 | 04:42 AM
Gwilkrrs's Avatar
Gwilkrrs
well i searched it-
downloaded to a thumb drive- put in usb in truck and after 1 hour nothing on the screen- nothing changed.....
then this am the gps wasnt working on the NAV.
gotta look and see where i went wrong......
Tryzub
Oct 12, 2023 12:02 PM
43FF
May 14, 2020 08:49 AM
Tigerlillyrk
21
Oct 30, 2019 11:00 AM
asphaltman
6.7L Power Stroke Diesel
May 9, 2010 02:42 PM
fatfenders
54
Dec 21, 2004 08:01 AM
