I'm having trouble locating the proper brake booster for my '86 e-250 van. Getting something that corresponds to the GVW seems to be an issue. Any ideas will be greatly appreciated.
Marty
What motor?
Does it have a 300-6 or a 6.9?
Some of the diesels had Hydro-Boost
Either way, you should be able to find one once you know exactly what you're looking for
If it is a diesel, and has a vacuum operated booster, double check the vacuum pump (with a vacuum gauge) before replacing the booster
Same with the one way valve, get a new one, or double and triple check the one you have before buying a vacuum booster
