Injectors
Old May 2, 2025 | 09:04 PM
Edwardba's Avatar
Edwardba
Trailering
Injectors
My 2002 f450 has been having some issues I’m pretty sure it’s a injector issue or head gasket .For the most parts it runs fine but I know something is wrong when I step on the gas to quick I hear it try to shut off and has light white smoke and let off the gas until it gets back to running smooth which just takes a few seconds off the gas . if under load I can’t go more than 50 without seeing heavy white smoke I try to avoid seeing any smoke before figuring out the problem .if it does end up being injectors should I go back with stock or is there something a bit more $ but worth it
Old May 2, 2025 | 09:19 PM
Pikachu's Avatar
Pikachu
First thing to check is fuel pressure, at wide open throttle, under load. You have a steel tank that has a reputation for the internal coating delaminating and plugging the screens in the tank. Low fuel pressure can easily cause the symptoms you describe.
Old May 3, 2025 | 12:03 AM
Wes444's Avatar
Wes444
For future trouble shooting reference
95% of the time
  • White smoke = not enough fuel
  • Black smoke = not enough air
  • Blue smoke = burning oil
The exception is on a cold start when it's below 45 degrees, white smoke can be a glow plug system issue
Old May 3, 2025 | 07:45 AM
RacinJasonWV's Avatar
RacinJasonWV
What the experts above said.
Also, low fuel pressure can damage injectors so get it checked quickly.
Old May 3, 2025 | 07:52 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
"An injector issue or a head gasket"
There are A LOT of things that fall between those two scenarios.
mitchell390
Mar 2, 2015 06:48 AM
Ford_250
Mar 18, 2011 06:49 AM
vanman250
1997 - 2003 F150
17
Sep 9, 2007 02:52 AM
bdonaldson
Sep 28, 2006 12:29 PM
stockernavstar
Jan 13, 2006 12:40 AM
