Engine Pulley
Old Apr 30, 2025 | 10:10 PM
smerchant's Avatar
smerchant
2nd Gear
Engine Pulley
I have a 68f100 with a 360; no A/C or P/S. The pulleys that came on the truck (C8AE-8509-A Water pump) & (C8AE-6312-E Crank) fit but are not for this year truck. I assume this would be fine? Are there any issues using these pulleys. I just had the engine rebuilt and don't want to mess it up.
Old May 1, 2025 | 12:46 AM
52 Merc's Avatar
52 Merc
If they came on the truck, why do you think they are not for this truck? If they worked before, they should continue to be perfectly fine, unless your plan was to add more engine accessories, like PS or air.
Old May 1, 2025 | 11:47 AM
smerchant's Avatar
smerchant
2nd Gear
The fortification pulley list led me to believe they are not right for this truck. The crank pulley is for a 428 or 390 and the water pump pulley is for a 390. I guess it doesn't really matter as long as they fit? Also, how close should these pulls be when installed? I can't squeeze a belt between them?
Old May 1, 2025 | 11:56 AM
RichS2659's Avatar
RichS2659
An FE is an FE pretty much across most FE engine sizes.
Old May 1, 2025 | 12:20 PM
52 Merc's Avatar
52 Merc
Pullies were used across multiple applications, and not every possible installed application could be listed. A belt would not go between the crank and water pump pullies. The belt goes around them. These are non stock parts shown here, but the idea is the same. It's the best example I could find quick. Besides, it's pretty.
Ford FE engine Ford racing engines, Engineering, Ford racing
Here's another look with more stock parts, but these are multi groove pullies. As you can see, the fit and belt orientation is still the same.
Ford 390 FE Engineering, Ford, Aircraft engine
Finally, as installed in a pickup, with power steering.
352 FE
Scrappy507
Sep 4, 2022 06:35 PM
biasvoltage
May 12, 2021 12:05 AM
59Fguy
Nov 14, 2020 06:35 PM
Mr Metals
Nov 1, 2019 08:51 PM
