Injector caps
Old Apr 28, 2025 | 07:53 PM
Akumothesaiyan's Avatar
Akumothesaiyan
Trailering
Injector caps
I have a 92 7.3 idi and recently I noticed that I have a lot of bubbling coming out the injector caps and bought a kit from car quest and viton orings from harbor freight. After installing I noticed that all the caps were loose even after snapping down and didn't think much of it. I fired up the truck and diesel came spewing out from under every cap. Just wondering what sets y'all would recommend going with because that car quest one was no good.
I found a mention of billet rails instead of caps in an older thread... Has anybody tried those? Here's the link to them https://idiperformance.com/shop/fuel-system/billet-injector-fuel-return-rails/. I feel like these would be nice in the long run
Old Apr 29, 2025 | 06:36 AM
Olds64's Avatar
Olds64
Do you still have the o-rings that came with that return line kit? If so, I'd use those over o-rings from Horrible Freight.
Old Apr 29, 2025 | 06:55 AM
Akumothesaiyan
Trailering
I do And I used those first with the same result I got the ones from harbor freight after the ones can come with the kit didn't work
Old Apr 29, 2025 | 07:26 AM
Olds64's Avatar
Olds64
What kit was it that you got at the auto parts store? Did you pre-lube the injectors before you installed the caps (chassis grease works great)?
Old Apr 29, 2025 | 07:37 AM
Akumothesaiyan
Trailering
I used Vaseline and the kit was carquest brand
Old Apr 29, 2025 | 08:16 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
I only use Delphi brand return line kits. Viton brown 111 o-rings sold separately. I've never had a failure after install on either truck since 2009 w/ f250 & 2013 w/ F450. The most issue I've ever had was perhaps making sure I pressed down hard enough on a cap or two after install. Once installed, I've never had a failure. Not even after disturbing a return line from time to time.
Old Apr 29, 2025 | 08:30 AM
WCMtn1990's Avatar
WCMtn1990
Well if every cap leaked then either they weren't pushed down all the way, every o-ring was the wrong size, or the caps are all sized wrong. There aren't that many variables with a return line kit. Or you could pony up for these, https://www.ebay.com/itm/356830931492
Old May 7, 2025 | 02:06 AM
Charmalu's Avatar
Charmalu
I reuse my caps, buy a bag of 50 Viton "O" Rings from McMaster-Carr, use to be around $10.
Size 111 Viton,
Put the whole side together as an assembly, (Caps and Hoses) can reuse the spring clamps.
Remove the old rubber rings off the Injectors, make sure the top are clean. Blow them off with
Carb Cleaner. grease up the new O Rings, put on the top one, then roll the 2nd one over the top
one. Grease up the inside the Caps, place ontop of the injectors, and push down till you hear them
click into place.
Charlie
TheFox302
Feb 7, 2011 08:30 PM
tfrugal
Jan 19, 2009 06:35 PM
AMDCAMARO
Mar 1, 2007 09:05 AM
Saigon
15
Sep 19, 2006 06:51 AM
salewit
May 9, 2004 11:11 AM
