95 E350 body panel help?
Old Apr 25, 2025 | 08:30 PM
Kibbers's Avatar
Kibbers
4wd Low
Good evening, I searched for a bit and am having a bit of a time finding my answer so I figured I'd make a thread.. I recently acquired a 1995 e350 ambulance that is missing the headlights, grill, passenger fender, header panel and the piece of metal that goes under the grill. Would I be able to order parts from a 97+ e series chassis and be good to bolt up or would modifications need to be done?
Thank you for your help!
Old Apr 26, 2025 | 12:56 AM
Conanski's Avatar
Conanski
That cab is the same as any other E series of that vintage.
Old Apr 26, 2025 | 04:52 AM
Kibbers's Avatar
Kibbers
4wd Low
So minor enough changes I can go grab something from the slight face flit era and go?
Old Apr 26, 2025 | 06:19 AM
JWA's Avatar
JWA
I found somes parts fitting that vintage at a Cleveland, Ohio outfil called Mil Supply---give them a look-see maybe.
Old Apr 26, 2025 | 07:27 AM
95CWChateau's Avatar
95CWChateau
Maybe...
Grille: I can install a newer grille on my 95 but I will have to cut slots to hold the lower grille tabs. Headlight buckets and related are different between composite headlines and rectangular. Newer grill will have ford emblem in grille and we also have ford emblem in our hood. I think at some point there there is a hood release mechanism modification required.
There are several folks who have done a front clip swap to the 2009 modern front end. Not so sure about mix and match. Heres a good thread on SMB forum that might help.
SMB front clip swap
Front clip swap more recent on Expo.
Old Apr 27, 2025 | 04:40 PM
maples01's Avatar
maples01
Be careful, sometimes gaps are spaced different, panels not stamped the same, junkyard is often the best for perfect fit.
Old May 4, 2025 | 07:34 PM
Kibbers's Avatar
Kibbers
4wd Low
Doing my best to go to a junk yard here and there. I managed to get a fender and various fasteners (Good ol pocket fuses/fasteners haha) She is coming together but looks like I may have to modify the 97 header panel a bit
Old May 6, 2025 | 07:27 PM
Kibbers's Avatar
Kibbers
4wd Low
One last question.. I am having a hell of a time finding the headlight retainer clips for the halogen headlights where you replace the bulb and not the whole headlight.. any reccomendations?
Old May 12, 2025 | 08:24 PM
maples01's Avatar
maples01
Amazon Amazon
Old May 24, 2025 | 11:22 AM
Kibbers's Avatar
Kibbers
4wd Low
Bit by bit!
Jrc79
13
Dec 18, 2021 08:53 AM
3twinridges
May 10, 2017 10:01 AM
Black1
Jan 6, 2016 12:15 PM
halfdone
Jan 16, 2005 06:21 PM
