Aluminim Winch bumper
Old Apr 25, 2025 | 07:35 AM
MOAK's Avatar
MOAK
I have been searching off and on for an aluminum winch bumper for my '24 350. I always end up in a circle of death using any of the search engines. Any ideas or links to share? Thanks
Old Apr 25, 2025 | 08:16 AM
nitebreeze's Avatar
nitebreeze
ICI has a nice aluminum winch bumper. Build quality, welds, back braces, and powder coating are all excellent. Unfortunately the ICI bumper has four light pod spots, so you will likely want to purchase four extra lights too. They have a matching aluminum rear bumper too.
ICI > Bumpers > FRONT BUMPER AL-FBM12FDN-RT: 2017-2022 FORD SUPER DUTY F250/F350/F450/F550 WINCH READY
https://www.icionline.com/alumilite/...550-2017-2022-
Old Apr 25, 2025 | 08:18 AM
nitebreeze's Avatar
nitebreeze
Old Apr 25, 2025 | 08:20 AM
nitebreeze's Avatar
nitebreeze
Old Apr 25, 2025 | 09:53 AM
350Recon's Avatar
350Recon
Buckstop bumpers have aluminum option.
The other is Truck Defender that only sends a price quote on pricing.
Old Apr 25, 2025 | 10:06 AM
nitebreeze's Avatar
nitebreeze
I had looked at Buckstop too, and liked their bumpers a lot, they look really good. When I finally decided to purchase, Buckstop no longer offered a matching rear bumper in aluminum.
Old Apr 26, 2025 | 08:18 AM
Buck-350's Avatar
Buck-350
@nitebreeze; Couldnt find the wieight of the ICI AL front- not sure if you're choosing aluminum for weight savings?
If you want to consider something from 3/16' steel, that has good approach angles, better looking design and function- @ #155lbs this bumper is custom made to a few different options: Superduty Modular Winch BumperDissent Offroad- Ive got his one of his bumpers on different truck now for 9 years - and its very well made.
Old Apr 26, 2025 | 08:37 AM
MOAK's Avatar
MOAK
that is what I’m looking for- thanks for your input. Yes, aluminum bumper for weight savings, but this steel bumper ticks all the boxes and it looks good, as if it were made for the truck, instead of an afterthought for any generic truck. It’s only about 40 lbs heavier than the stock bumper. I’ve bookmarked it for the future. I really like the Expedition One line of bumpers but they are god awful heavy. My old truck had about 500 lbs of bumpers & sliders- I’ll not do that again.
Old Apr 26, 2025 | 09:12 AM
nitebreeze's Avatar
nitebreeze
I was looking at aluminum bumpers for both reduced weight and durability. I like some of the steel winch bumpers a lot, but not the extra weight of steel. I was figuring not just the extra bumper weight, but also an additional hundred pounds more added weight from the heavy winch cradle and winch weight. ICI came closest to best for me.
Old Apr 26, 2025 | 09:26 AM
seijirou's Avatar
seijirou
Is this for looks or function? Winching aluminum is asking for trouble, I'd think twice. This one ripped at the mounts winching out of mud. Winching forces can exceed vehicle weight by several times. If it's for looks, nothing wrong with that. Game on.
Old Apr 26, 2025 | 09:56 AM
nitebreeze's Avatar
nitebreeze
The ICI bumper winch cradle is heavy steel, and the welds look good, and each side has four bolts through the top of each frame, and two bolts through the side of each frame, all using existing frame holes, and the winch mounts bottom forward so no torque stress on the winch mount bolts. The ICI winch cradle seems good as much as I can tell. The aluminum bumper is mounted to the frame using different brackets ( isolated to deter galvanic corrosion). I hope my winch is only for looks though, and if I need the winch, hopefully the winch pull is for another stuck vehicle. With this winch so far I only used the winch to pull a small tree stump. I have had my vehicles stuck many times, but never yet and hopefully never ever bad enough to break the winch off.
Old Apr 26, 2025 | 10:10 AM
seijirou's Avatar
seijirou
Ah a hybrid bumper of steel and aluminum. That makes a lot of sense.
Old Apr 26, 2025 | 02:44 PM
MOAK's Avatar
MOAK
well, I’d never use an aluminum winch plate, otherwise ya, the pulling force would rip it up soundly, unless you use an unobtanium aluminum alloy plate, which would cost more that the bumper.
Old Apr 26, 2025 | 09:46 PM
Buck-350's Avatar
Buck-350
Yeah for sure - it’s a good design and Ben ( owner @ Dissent) designs a very stout bumper. I believe they’re all made to order so if you decide to go that route plan ahead for lead times.
good luck👍
Skidrowvet
2021+ F150
17
Apr 28, 2025 08:57 PM
blieux1
6.7L Power Stroke Diesel
Oct 14, 2011 12:14 PM
14&Ford
Nov 20, 2010 09:57 PM
tirch
Oct 18, 2005 04:04 PM
